back firing issues?
Old Feb 4, 2008 | 09:55 AM
mbolte's Avatar
Car: 1987 Camaro
Engine: 350 dart ies comp cam intake carb
Transmission: 700 r4, shift kit, 2400 stall
Axle/Gears: 10 bolt stock
back firing issues?
well i just finished putting on some dart iron eagles (180cc,64cc) and i finally got it all together and it backfires now when i let off from high rpm like say after a 1/4 mile run(its an auto) and when it does it at night i can see the flame, the motor is a 350 with 274 cam rpm intake and those heads
is this something i should worry about...i have the timing advanced to 8 degrees, but there is also a bad exhaust leak because i cant get the last header bolt in on the back of the passenger side header, or could it be a valve setting problem?
Old Feb 4, 2008 | 10:01 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Re: back firing issues?
I wouldn't worry much about it. It can be embarrasing though. Probably not a valve setting issue. The different combustion chamber shape probably wants a different timing curve.
You may want to go leaner on your idle mixture and lower on the idle RPM setting.
Uneven fuel distribution with one cylinder too rich can cause this also.
mdtoren
Aug 23, 2015 12:52 PM
86White_T/A305
Aug 17, 2015 12:16 AM
mdtoren
Aug 16, 2015 05:45 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
djmarch
Aug 9, 2015 05:27 PM
