383 balancer?'s
Old Feb 6, 2008 | 11:55 AM
grove's Avatar
Car: 1988 firebird
Engine: 305 tpi
Transmission: 95 T56
Axle/Gears: stock 10 built, yukon diff, 4.10
383 balancer?'s
i ordered a 383 kit, with an eagle crank, externally balanced. i opted not to my the balanced kit because im gonna be putting a t-56 in and ill have to use a 4 th gen flywheel. im tyring to figure out which harmonis balancer to use for a reasonable price. i dont wanna drop 2-300 bucks on the damper. i know the damper has to be for a externally balanced engine and for the 400. im not gonna be running this higher than 6500 continously. it will be primarily street driven. maybe see the strip maybe once or twice a year if that. so which damper would be best for a reasonable amount of money. less money i have to dish out for the balancer the better. i know you get what you pay for.
Old Feb 6, 2008 | 01:22 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I think you've made a big mistake. If this is a one-piece rear main seal crank, then get it internally balanced. A LT1 flywheel will bolt to it without any further balancing needed. And, you can use a neutrally balanced damper up front.
Stop the order if you can.
Old Feb 6, 2008 | 01:25 PM
grove's Avatar
Car: 1988 firebird
Engine: 305 tpi
Re: 383 balancer?'s
whats wrong with external balanced?
Old Feb 6, 2008 | 01:33 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 383 balancer?'s
You'd have to find a flywheel that's balanced to the 400 spec (which is what an externally balanced 383 most likely is). With an internally balanced setup you can use a stock flywheel.
Old Feb 6, 2008 | 01:37 PM
grove's Avatar
Car: 1988 firebird
Engine: 305 tpi
Re: 383 balancer?'s
ohhh ok. i havent purchased the flywheel yet.
so this is what im understanding. is if im gonna run a t-56 from a 94-97 camaro/ firebird, with the stock flywheel then i need to re-order the stroker kit to be an internal balance kit.
but if i dont re-order, and stay with the external balance kit, im gonna have to find a fly wheel and those im taking it cost alot more.
which is better to have an external kit or an internal kit?
Old Feb 6, 2008 | 01:41 PM
Re: 383 balancer?'s
The one that WORKS with the least putzing around.
Whch would of course be, stock (internal) balance. Assemble, bolt up, done. No worries.
Old Feb 6, 2008 | 01:49 PM
grove's Avatar
Car: 1988 firebird
Engine: 305 tpi
Re: 383 balancer?'s
would i be able to use a 350 balancer then? would i still have to use a 400 balancer?
Old Feb 6, 2008 | 01:54 PM
Re: 383 balancer?'s
You'd use all your stock stuff. Assemble, bolt up, done. No 400 anything.
Too easy. Don't outsmart yourself over it.
Get the right "kit", and put all that "external" crap in your rearview mirror.
Old Feb 6, 2008 | 02:00 PM
grove's Avatar
Car: 1988 firebird
Engine: 305 tpi
Re: 383 balancer?'s
ok, onto my other question, would a stock balancer be good enough? like i said before im not gonna be running 6500 constantly. and im hardly gonna see the track?
also which size balancer? i know they come in different sizes. should i get a stock 89 L-98 balancer. or when i get the t-56, should i get a balancer that matches the year of the transmission.
Old Feb 6, 2008 | 02:05 PM
Re: 383 balancer?'s
Your stock one should be fine, if it's in good shape. If the rubber is deteriorated, get a stock replacement one, like a Pioneer.
The crank damper is not connected in any way with the transmission. It does not even care if there's a transmission there, let alone what kind or year it is. Its function is not related to the trans.
Old Feb 6, 2008 | 02:10 PM
grove's Avatar
Car: 1988 firebird
Engine: 305 tpi
Re: 383 balancer?'s
thanks for knowledge. now im trying to get a hold of the company i ordered the kit from.
so for a quick review, internal 383 balanced kit, stock 350 damper, stock flywheel, correct?
Old Feb 6, 2008 | 02:38 PM
five7kid's Avatar
Stock LT1/T56 flywheel - yes.
Just to make sure all the bases are covered, what block will you be using?
Old Feb 6, 2008 | 02:47 PM
grove's Avatar
Car: 1988 firebird
Engine: 305 tpi
Re: 383 balancer?'s
89 L-98 block, 2 bolt main, roller motor. casting # 14093638
Old Feb 6, 2008 | 04:17 PM
five7kid's Avatar
Just make sure the crank in the stroker kit is for that block. Would hate to hear you ended up with a 2-piece rear main seal crank.
A lot of the internally-balanced (okay, for sofa's sake, "stock balance") kits are one-piece rear main seal.
I've got a Pioneer damper on my 350. It would work just fine for your stroker as well. Nice piece, much better than the stock stuff.
Glad we caught you before you got in too deep.
Old Feb 6, 2008 | 04:58 PM
grove's Avatar
Car: 1988 firebird
Engine: 305 tpi
Re: 383 balancer?'s
i called the company, and there changing my order to internally balanced 1 piece rms. yeah it was a good thing that you guys helped it, or else i would have been spending more money than i have to.
i was pretty much gonna buy a damper just for a piece of mind.
Old Feb 6, 2008 | 05:08 PM
five7kid's Avatar
All's well that ends well.
LT1Formula
Oct 8, 2015 08:34 PM
monte87cortez
Sep 26, 2015 08:10 PM
