prom change info needed
Car: 85 camaro z28
Transmission: auto to manaul
i need to get a manaul prom. i have the rare 85 tpi ecm. would the BURN1 Flash-n-Burn work 4 me?
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: prom change info needed
you can buy all the moates stuff and use tunerpro to make it a manual prom. you'll need burnable chips, his adapter to plug chips into the stock ecm and that burn1 programmer. Should be all you need to start modifying the bins/proms
