Compression diffences in a 350
Old Feb 7, 2008 | 11:36 AM
Travis&camaro's Avatar
Car: 1984 Camaro
Engine: BIG BAD 360!!!!
Transmission: th350 shift kit 3600 stall
Axle/Gears: 3:73 posi
HI, I have a 79 350 thats all rebuild and in the car. I built my short block with a egal crank chevy stage 2 rods and speed pro flat top hyper pistons. the block is bored .060 over if that makes a differnece. My pistions are supposed to have a 9.67 compression with 64cc chamber. My friend keeps telling me my cars going to have no power b/c hes running 10:1 compression. Im going for 450hp and the machine shop told me I would make it with my 245 duration cam with 510 lift. Now how much Hp difference would it make if I would of did a 12:1 or say 11:5 compression. What would the hp difference be? If its big Im willing to change but I have every thing balence to these pistions and engine is built and haven been ran yet. Whats the highest compression I can get in a flat top pistion.
Let me know what you guys think.
Old Feb 7, 2008 | 11:50 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Compression diffences in a 350
I can't see what heads you're running there? 64cc chamber and...?
What's the deck height, measured?
Assuming iron heads, anything over 10.5:1 or so (with that giant cam) won't run well unless you're mixing your own race fuel. If you plan on driving it on the street i'd forget about any higher.
Which cam do you have? Part number and brand?
Flat tops in a 350 would max out at ~10.3:1 or so, with a 64cc head. That's exactly what I have.
Old Feb 7, 2008 | 11:52 AM
mxcrazed's Avatar
Car: 87 firebird none soon
Engine: None
Transmission: none
Axle/Gears: 2.73 10 bolt
what are your heads made out of, that limits your compression due to cooling
Old Feb 7, 2008 | 12:00 PM
Car: 1984 Camaro
they are aluminum votec style.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
buffaloman
Firebirds Wanted
Sep 7, 2015 09:47 AM
buffaloman
Camaros Wanted
Sep 7, 2015 09:46 AM
85Special
Sep 3, 2015 04:21 PM
Formula_88AE
Sep 3, 2015 01:47 PM
