help finding a new cam
Old Feb 12, 2008 | 03:39 PM
89305formula's Avatar
Car: 89 formula
Engine: 305tpi
Transmission: t-56
Axle/Gears: ford 9" 4.11s
this year im getting rid of tpi and going with a carb i already bought a wiend stealth manifold and a 650dp carb but i figure i might as well change the cam out to i want to stay with hydraulic roller cam but i want to go bigger then what i have , comp 276hr, so basically any suggestions on a bigger cam would be helpfull, also im trying to do this as cheap as possible if that is possible
Old Feb 13, 2008 | 11:20 AM
hitman0187's Avatar
Car: 87 Iroc 5.7 /86 Trans am
Engine: 5.7 TPI / 350 carb
Re: help finding a new cam
My suggestion is to not use a bigger cam on a 305ci motor. You may want to if anything change the rockers to 1.7 and maybe a higher stall converter paired with a lower rear end ratio.
Old Feb 13, 2008 | 11:37 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
1.7:1 rockers on a Gen I SBC? 305, no less? I don't think so.
The 276 will be fine, assuming you have adequate valve travel.
Old Feb 13, 2008 | 01:54 PM
Car: 89 formula
Engine: 305tpi
Transmission: t-56
i dont have a converter being that its a stick and i already have 4.11s and im going through the traps about 200rpm before limiter so im not changing my gears either, and i have never heard of 1.7s for a gen 1 only lsx motors, i might keep the cam in there till maybe mid season and see how i like it with the carb cause with the efi it was to much not being tuned, and be springs should be good to .600 lift thats why i was thinking about going alittle bit bigger, also is there any benefit to using a rev kit cause i would like to put a bigger shot of nitrous on it but i float valves at about 6500 and i would like to turn more rpms and see what i can get out of this 305, would like to get mid to low 12s on motor high 10s on a 200 shot
Old Feb 13, 2008 | 03:06 PM
hitman0187's Avatar
yeah, rereading everything nix the 1.7s its 2nd nature as the "list" progresses. your only other option may be better flowing heads at this point, you seem to have everything else under control.
gta90
Sep 15, 2015 04:00 PM
Reborn756
Sep 4, 2015 03:42 AM
camaro71633
Sep 1, 2015 10:24 AM
1988iroc350tpi
Aug 14, 2015 07:52 PM
