block question
Old Feb 14, 2008 | 10:35 PM
slow89's Avatar
Car: 89 irocz
Axle/Gears: 373
block question
i have just recently got a short block built for my car. how do i find out what year the block is??
Old Feb 14, 2008 | 10:47 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Re: block question
There are casting numbers on the drivers side rear of the block, they will give you a vague idea.
One peice or two on the rear main?
Drilled/milled for roller lifters? (looks like it is.....)
Old Feb 14, 2008 | 11:15 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: block question
Yea, looks post 1987. Call it a 1990 and move on.
Old Feb 15, 2008 | 01:44 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: block question
Pasted from http://www.nastyz28.com/sbchevy/sblock.php#cdate
Casting Date
Small block casting date is located on driver side rear of block on flange forward of bellhousing. Big block on the right side of engine above the oil pan rails.
Casting Date Example: E038 - (E = Month, 03 = Day, 8 = Last digit of model year (1978)).
Month: A = Jan, B = Feb, C = Mar, D = Apr, E = May, F = Jun, G = July, H = Aug, I = Sep, J = Oct, K = Nov, L = Dec
BlackphantomZ28
Aug 22, 2015 01:00 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
BBSDesigns
Aug 11, 2015 07:39 PM
