replacing drive belt tensioner
Old Feb 15, 2008 | 12:57 PM
north_oakland's Avatar
Car: 1989 Camaro
Engine: 2.8L
I have an 89 camaro with a 305 tbi and I need to replace the drive belt tensioner but i dont see any bolts to remove it. Any advice? thanx
Old Feb 16, 2008 | 11:03 AM
squirted1's Avatar
Car: 84 Trans Am
Engine: 383
Transmission: Tremec TKO
Axle/Gears: 10 bolt 3.73 lsd
Re: replacing drive belt tensioner
in the center of the pivot area is a recessed torx head bolt(T-55 i believe). remove tension before loosening the bolt. there is a locating dowel behind there so it can only go on one way. hope this helps
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
Infested
May 22, 2018 11:56 PM
mcquigg
Aug 13, 2015 02:26 PM
