Identify this...
Old Feb 17, 2008 | 05:07 PM
Oscar's Avatar
Identify this...
This is apparently some sort of vacuum tee. The larger end goes to a port in the plenum. One small end to the vacuum line that apparently opperates the a/c ducts. The other smaller one goes to I believe the cruise control gear. This looks to be some special design and does not run straight through on in inside. I know this because you cannot see straight through where the holes line up.
Can someone tell me if there is something special about this "vacuum tee"? Why this design?
Thanks.
Old Feb 17, 2008 | 05:17 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
Re: Identify this...
Ive always wondered the same thing. It is what you say it is cause thats the same way mine is routed. Can you blow thru it?
Old Feb 17, 2008 | 05:21 PM
jvontungeln's Avatar
Car: 83 Camaro
Axle/Gears: 342's
Looks like a tee with a check valve to keep the blend doors from constantly opening and closing due to acceleration. NAPA sells them.
Old Feb 17, 2008 | 05:26 PM
Oscar's Avatar
you can blow through it in all three directions and you can suck air from all three also. I was trying to see if it was some sort of valve. there's got to a reason for the this design. Maybe I will cut it open to look inside.
Old Feb 18, 2008 | 04:56 PM
Oscar's Avatar
Got it. Went to a parts store and confirmed it is a "vacuum check valve". AC Delco part# 14056648. I put it in, and my a/c vent doors don't activate anymore on engine start up. All works perfect now.
92firebirdguy
Sep 1, 2016 07:53 AM
luvofjah
Sep 26, 2015 08:28 PM
Linson
Sep 21, 2015 01:08 PM
Tweeks25
Sep 17, 2015 08:04 AM
Blue419
Sep 10, 2015 01:03 PM
