Where's the pump?
Old Feb 18, 2008 | 07:06 PM
marolover30587's Avatar
Car: 87 camaro
Engine: 305, Stock?
Where's the pump?
I have an 87 camaro(305 W/700r4) that my grandpa bought, the guy he bought it from rebuilt/took out/ screwed with the engine. from what I can see it is all stock. but now there is gas getting into the oil. I pretty much know its the fuel pump, so can any one tell me where it is?
Old Feb 18, 2008 | 07:23 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: Where's the pump?
Oil getting into the gas? how do you know this? How do you know its a fuel pump issue?
Old Feb 18, 2008 | 07:36 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
It's impossible to get oil into the gas. The fuel pump is electric and inside the fuel tank. It will supply fuel to the engine and what isn't used will be returned to the tank. Nowhere in the system will oil get anywhere close to the gasoline.
If for some reason you have a mechanical fuel pump and a carburetor, the fuel pump is mounted at the right front side of the block. There is no pressurized oil there so again, there's no way to put oil into the fuel. A mechanical fuel pump has a better chance of putting gasoline into the oil than the other way around.
Old Feb 18, 2008 | 08:20 PM
Car: 87 camaro
Engine: 305, Stock?
Sorry gas into oil typo fixed it though
Old Feb 18, 2008 | 09:41 PM
squirted1's Avatar
Car: 84 Trans Am
Engine: 383
Transmission: Tremec TKO
Axle/Gears: 10 bolt 3.73 lsd
if the electric pump is on with the engine off, the fuel could potentially make it past the seat, go into the intake, and fill the cylinders with fuel, which would leak past the rings and down into the oil pan. make sure that the pump is not running continuosly while the engine is not running.
Old Feb 18, 2008 | 09:48 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Then if you have a mechanical pump on the side of the block it could be leaking past the diaphram and leaking into the oil
Old Feb 19, 2008 | 11:43 AM
Car: 87 camaro
Engine: 305, Stock?
Its definately a mechanical, as there is no switch inside, but i'll look into it
Old Feb 19, 2008 | 12:46 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
There's no switch inside for the electric fuel pump.
I'm a little confused how you could know it's mechanical but not know where it is. Oh, because you don't see a fuel switch inside the car. Never mind.
Is this engine carburetored or TPI? If TPI, there is no mechanical pump.
If it's carburated, it has both a mechanical pump mounted on the front passenger corner on the side of the engine just above the oil pan, and an electric inside the fuel tank. This was a 1987 model year only thing (from the factory - the in-tank could be added by the dealer as a "vapor lock" kit), and coincidently, the last year of a carburetor on f-bodies.
Old Feb 20, 2008 | 09:22 AM
Car: 87 camaro
Engine: 305, Stock?
I fixed it, thanks for all the info it was the mechanical pump I currently now feel like an idiot for not seeing the pump. only took me half an hour to change it.
Hotrodboba400
Dec 10, 2019 07:07 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Gunsbee
Sep 7, 2015 07:10 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
