knock sensor?
Old Feb 19, 2008 | 07:01 AM
davr89's Avatar
Car: 2004 Silverado SS
Engine: 6.0L LQ9
Axle/Gears: 4.10 AWD
knock sensor?
hey guys,
in march i will be converting my 305tbi to tpi and i bought a full set up off of a guy from my local fbody club and he said i have everything but a knock sensor. now my question is, what is a knock sensor? and what does it do? and what kinda price do they usually go for?
thanks!
Old Feb 19, 2008 | 07:35 AM
Big Dave's Avatar
Car: 1992 RS Heritage
Transmission: TCI 700r4
Re: knock sensor?
Knock sensor senses spark knock/detonation and help computer control timing. Its located on the passenger side of the block, below 4&6 spark plugs. Its round and has a single wire connector. Yes, you need to change it when swapping TBI to TPI. I think they're about $35.
Dave
Old Feb 19, 2008 | 11:45 AM
davr89's Avatar
Engine: 6.0L LQ9
Re: knock sensor?
any thing else i should change/replace when i do the swap? im planning on slapping a LT1 cam in at the same time, and aluminum L98 heads too if i can find them.
Old Feb 19, 2008 | 01:21 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Re: knock sensor?
I don't know why that would be the case. It's still a 305, TBI and TPI use the same sensor.
Old Feb 19, 2008 | 03:02 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
Re: knock sensor?
you dont have to change it. your just putting a different injection system on it. knock occurs within the block which youre leaving the same.
Old Feb 20, 2008 | 08:08 AM
Big Dave's Avatar
Re: knock sensor?
When I did my swap, I came up with two different part numbers for the knock sensors, so I changed mine.
Dave
Old Feb 20, 2008 | 12:28 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: knock sensor?
Far as I know, there are two knock sensors for the V8 3rdgens - one for the 305, one for the 350. TPI/TBI/CC Carb doesnt make any difference. Your TBI setup should already have a knock sensor - its right in the bottom of the right side of the block, just in front/above the starter. You'll know it when you see it. Just use yours if you are staying with the same engine and just changing the EFI system.
FWIW I used an L98 knock sensor with my CC Qjet on top of a 350 and it worked just fine.
Old Feb 21, 2008 | 05:29 PM
lind90's Avatar
Car: 91 RS
Engine: 305 tpi
Transmission: auto
Axle/Gears: ford 9" w/4.11
Re: knock sensor?
I just did this same swap on my 91, went from tbi to the tpi from a 91 z. I ended up having to change the knock sensor because it thru a code. Changed it to a knock sensor from a tpi, haven't had a issue since. Good luck with the swap
L98GTA87
Oct 19, 2015 10:43 PM
cking99
Sep 22, 2015 11:33 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
BLK87Z
Sep 18, 2015 11:29 PM
FormulasOnly
Sep 10, 2015 09:07 PM
