quadrajet swap?????
Old Feb 23, 2008 | 10:39 AM
fychelio's Avatar
Car: 1983 pontiac Trans am ws6
Axle/Gears: ????
quadrajet swap?????
i have a brand new 4 barrel quardajet manual carb, and i wanted to se if i can just swap over the electric pieces and choke from my 4 barrel quardajet thats on the car???
Old Feb 23, 2008 | 10:43 AM
Re: quadrajet swap?????
Possibly...
Pics & part #s would help.
Old Feb 23, 2008 | 11:15 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
You mean swap from your existing computer controlled Q-jet to a non-cc Q-jet?
No, not really. You'd need to swap distributors and also find a way to control your torque converter lockup.
If that's what you're talking about.
Old Feb 23, 2008 | 12:06 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Originally Posted by Sonix
...If that's what you're talking about.
I think he's talking about transplanting his CC guts into another non-cc Q-jet.
The answer would be no.
No provision for mounting the TPS.
Old Feb 23, 2008 | 12:21 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Your biggest problem is this part: "San fernando Valley". You need a CC carb to pass smog inspection.
But, if you're trying to fix some problem with your CC carb by using a non-CC carb for a base, it won't work. If you're trying to replace some missing parts from the non-CC carb with parts from the CC carb, the choke is one thing that will work, and probably the idle kick solenoid, but your main problem is still in the first paragraph.
colton_carlson
Mar 8, 2019 12:21 PM
Infested
May 22, 2018 11:56 PM
Thaney9
Aug 29, 2015 03:16 PM
theshackle
Aug 22, 2015 06:52 PM
armybyrd
Aug 10, 2015 09:23 PM
