FInding an oil leak
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
FInding an oil leak
Okay, i'm leakin oil somehwere and i cant find out where, i know my oil pan seal is a bit shotty so im gonna get a new gasket for that, and i THINK its my timing cover too, i changed my valve cover gaskets a few months back and those are still good, when i look under my car i notice a line of oil beading down my lower radiator hose, its kinda thick around the timing cover too, how hard is it to do the timing cover and how do i do it?
ALSO...are there any notorious leak spots i should know about??
Car: 88 GTA "Cocaine"
Engine: 350 tpi
Re: FInding an oil leak
buy the one piece oil pan gasket
do the oil pan and the timing gasket at the same time
while you are at it you might as well get a rear main seal oil pump and a timing chain
drop the oil pan then the timing cover. put the cover on first and then the pan.
Just make sure you don't blast directly into any electrical things, and above all, the distributor.
It's a WHOLE LOT easier to spot a leak on a freshly clean surface than on one with a hundred thousand miles of accumulated funk.
Not to mention, when time comes around for working on it, it's a WHOLE LOT less unpleasant to work on a clean motor, than on one where you have to wallow around for days in an inch of slime and goo.
Smog pump been hacked off of it?
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
nope everything is still there, bone stock with all original or oem parts everythime i get it on a lift i've been tackling the nasty parts, i scrape my entire oil pan last time...which did me no god because it rained and now its caked in mud lol
Navy8125
Aug 21, 2015 09:32 AM
