HP ESTIMATE AND LIFTER QUESTION
Old Feb 24, 2008 | 05:00 PM
xyzman's Avatar
355 CI FLAT TOP PISTONS 4 VALVE RELIEF 9.75 COMPRESSION, LUNATI VOODOO CAM 227/233-489/504, VORTEC 906 PERFORMANCE HEADS 550 LIFT SPRINGS PRO PRODUCTS AIR GAP VORTEC CROSSWIND MANIFOLD DUAL PLANE, GASKET MATCHED,HEI, 750DP HOLLEY CARB,1" SPACER, STEEL ROLLER VORTEC 1.5 ARMS. AND ON THE LIFTERS WHICH WERE PURCHASED USED ALONG WITH THE CAM WHICH HAD ONLY DYNO TIME ON BUT WERE NOT MARKED AS TO WHAT HOLE THEY WERE TAKEN OUT OF, SHOULD I USE THEM OR JUST BUY NEW LIFTERS, ALSO 4 OF THE LIFTERS HAVE SLIGHT USE CIRCLES ON THEM THOUGHTS ??
Old Feb 24, 2008 | 08:01 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Re: HP ESTIMATE AND LIFTER QUESTION
350-370 hp or less depending on who puts it together and tunes it.
Unless those are roller lifters, ya gotta toss 'em.
...and stop typing in all caps. People will think you're an AOL user.
skip91
Sep 24, 2015 03:29 PM
Mickeyruder
Sep 2, 2015 02:45 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
Cameeeero
Aug 20, 2015 03:06 AM
redmaroz
Aug 16, 2015 11:40 PM
