Oil pan gasket change
Old Feb 24, 2008 | 07:42 PM
spiderhole's Avatar
Car: 86 z28 LG4 305ci
Engine: LG4 305ci
I am reading that, and it sounds like, I have to jack the engine up slightly to get the oil pan out. Theres a leak down there which I can only assume is the oil pan becuase I don't see any other obvious leaks.
If I have to get at it, what is the method specifically of getting the engine into a postition where I could do the job? Thanks
Old Feb 24, 2008 | 09:24 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Re: Oil pan gasket change
the ideal situation would be to put it on a lift and use a rotating jack on the harmonic balancer to lift it up
The reality of it being you probably dont have access to a lift, so just put the car on ramps and use a good jack on the harmonic balancer it should give you enough room to do it
Good luck
MoJoe
Sep 24, 2015 09:12 PM
Navy8125
Aug 21, 2015 09:32 AM
articwhiteZ
Aftermarket Vendor Review
Aug 18, 2015 07:26 AM
MY87LT
Aug 17, 2015 08:43 AM
gwade12
Aug 8, 2015 08:17 AM
