re-using stock bore, and re-using rods/pistons
Old Feb 24, 2008 | 08:56 PM
offsetfactor's Avatar
Car: 89 Camaro RS
Transmission: Turbo 350
So, I picked up a cheap used block, has no cylinder rust, and was running fine when disassembled. I am taking the crank to get cleaned/turned and the rods to get re-done, and im going to have them check the pistons.
If the pistons turn out to be good (dont see damage on the side skirt), should my block just need a glaze breaker ran through it? There are no scratches down the cylinder walls.
I figured if the pistons checked out ok, i could just run a glaze breaker and then use plastigauge on my crank after having it turned to make sure the line is within spec
Ive done 4 cylinders before, but this is my first v8
Old Feb 24, 2008 | 10:33 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: re-using stock bore, and re-using rods/pistons
You'd have to measure the cylinders with a bore gauge to see if you can get away with just a honing.
Genopsyde
Oct 7, 2015 08:35 PM
gta90
Sep 15, 2015 04:00 PM
NinjaNife
Aug 23, 2015 11:49 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
