Please help me compare 383 crate engines.
Old Feb 25, 2008 | 08:12 PM
Graham M.'s Avatar
Car: '90 GTA
Engine: 305 (for now)
Axle/Gears: 2.90
Hey guys, I just wanted to say thanks in advance for reading this, and providing any help you can on this. I'm torn between three engines.
Price is a BIG factor, as I'm trying to get as much bang for the buck as I can.
Here is the first one. Its a 525hp 383 from Speedomotive. Its $7,750
http://www.speedomotive.com/ps-473-6...er-engine.aspx
here is the other one from Speedomotive, only this is a 450hp one for $5,600
http://www.speedomotive.com/ps-163-6...er-engine.aspx
^ This one seems to be build rather cheaply though.... judging by the upgrade list below.
The last one is a whole $10k. Its Proformance unlimited's 510hp 383.
http://www.proformanceunlimited.com/...3_450drop.html
I cannot build my own engine, as I dont have the know-how or the tools (etc). I need something incredibly reliable as this is going in my daily driver, grocery getter, commuter; GTA.
Any light or other engines you guys know of, please let me know.
I really could use you (guru's) help on this, so any tips at all would be great.
Old Feb 25, 2008 | 09:44 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: Please help me compare 383 crate engines.
I don't think you will be happy with any of them if you want your car to also serve as a grocery getter. I also think your T5 transmission will be crying uncle before long. If you have a 10 bolt rear end it won't be to happy either.
Old Feb 25, 2008 | 10:08 PM
Graham M.'s Avatar
Car: '90 GTA
Axle/Gears: 2.90
Thats what the guys were saying, being the T5 not being able to handle the torque. I'm looking into a Tremec as well for it. For the rear end? dont know yet.
I know its overkill, but I also would like a car that can cut it for track nights as well.
Old Feb 26, 2008 | 11:14 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
I can't say strongly enough.....stay away from Speedomotive.
Do a search on their name.
Old Feb 26, 2008 | 06:01 PM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
Axle/Gears: 3.73 moser 12 bolt true trac
zz383 check it out.
Old Feb 26, 2008 | 06:59 PM
Graham M.'s Avatar
Car: '90 GTA
Axle/Gears: 2.90
thank you. I'll do that now.
Old Feb 26, 2008 | 07:09 PM
Damon's Avatar
For a dual-purpose car it's tough to beat a mild engine combo with a plate nitrous system on top. Docile and resonably ecomomical for daily driving, but an animal at the track when you open up the bottle.
N/A small blocks, even 383s, pushing 500+ HP are going to be a bit raucous for regular street driving and you will quickly tire of the regular fill-ups of premium fuel. Then again, if you've got $10K to drop on an engine maybe you won't mind so much.
I second the suggestion of a GMPP ZZ383 motor. It's a fairly aggressive combo putting out 425HP, but not an overly-aggressive lumpy misery puttering around town. And it's made by the mother ship which means it's gone through the same durability torture tests that GM puts all their production line motors through. You can build more power for less money, but you can't always beat a GM engine for durability and overall value. I also wouldn't be too scared to throw a small plate shot of nitrous at it.
No comment on Speedomotive other than to say I've had mixed resuts the few times I've dealt with them.
Old Feb 26, 2008 | 08:20 PM
Graham M.'s Avatar
Car: '90 GTA
Axle/Gears: 2.90
Thanks, well after some more searching, the GM performance parts line up seems to be the best, as their crate engines are ****-beat to the nines for testing, much like all their other engines, so I'd feel very confident with a GM performance parts one.
Is the (ZZ) 383 425hp a decent choice? www.cratenenginedepot.com has it for a little more then $5k for an (almost) turn key engine.
The T5 can handle 425hp without too many difficulties I believe I read... is that true? how about the rear end?
I love the torque curve on that fast burn 383, its as close to flat as I've ever seen on any engine.
(thanks for the heads up on Speedomotive, their a little too "hit & miss" for me.)
EDIT: just a quick question, I normally drive quite sparingly on the gas, and with the 2:90 gearing I'm currently using, what can I expect fuel economy wise?
Thanks again guys.
Old Feb 26, 2008 | 09:21 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
I would reccomend checking out T and L
They built my engine and i have nothing but good things to say about them, and their prices are very good.
http://www.tandlengines.com/
check'em out, or give them a call, i found them very helpful.
Old Feb 27, 2008 | 07:41 PM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
that t5 trans will be history with that zz383 unless you drive like my wife.
Old Feb 27, 2008 | 07:58 PM
jeffcj's Avatar
My shortblock 383 is being put together by T&L right now. Great people to talk to and work with. They know they're stuff. It is owned by Lloyd McCleary, who used to build engines for NASCAR. Yes, I know half the ads on E-Bay for different companies say the same thing, but I actually did some research...
http://www.nascar.com/races/truck/19..._official.html
CONTINGENCY AWARDS
AE Clevite Engine Builder: Lloyd McCleary,#61, IWX Motor Freight, Dodge
...Oh.. one thing! T&L is currently running about 4 weeks on short blocks, not sure about turn key crates. They're busy people but I am confident it will be worth the wait.
Old Feb 27, 2008 | 10:34 PM
Comp788's Avatar
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
I have a ZZ383, a T56 and a 9" ford rear end. It is a great package.
Old Feb 28, 2008 | 08:58 PM
Graham M.'s Avatar
Car: '90 GTA
Axle/Gears: 2.90
^ Ford rear end? was that hard to install? are there any other options. I'd like to have about 3:23-3:55 rear gearing, with something above 400hp. Too bad the T5 is a very weak transmission. I'm going to try to hunt down a used TKO-600 now, or check for a reman. one, as $2k isn't something I was budgeting for.
CONTINGENCY AWARDS
Thanks for the link by the way. It looks like either the ZZ383 or something from T & L is the way to go. I can't believe T & L's prices. Its like speedomotive, but with the suck **** turned down to zero.
T & L Looks to be a very good choice. Proformance seems very good, but their prices are very high. I was hoping to avoid proformance, same with Golen engine service.
Old Feb 28, 2008 | 10:09 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Those 5.565 inch rods are pretty lame in the cheap speedomotive motor. For that kinda money I'd expect something pretty impressive, but whatever.
I put together what is, in my opinion, a nice motor for less than 3 grand. I dont know where the other 2 grand go?
But then I didnt need a fully forged bottom end so you save around $1000 there. But those engines from speedomotive don't have forged bottom ends either. 2-bolt mains too? Yuck. Not that it really matters, it's just one of those "For the money" things, even though I've also got 4-bolt mains.
But mine is a 350... It simplifies a lot of things, and saves some money. But sometimes I wish I had done the 383 thing. I'd probably have spent an extra $500 doing it, though.
Old Feb 29, 2008 | 08:16 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
If you wern't planning on an extra 2k to be spent on a tranny you need to think about some things. You need to budget in the supporting mods you will need. Figure around 2k for a tranny, another 2k for a bolt-in rear diff (12 bolt or 9 inch), a couple hundred for subframe connectors. etc. Also keep in mind I'm probably lowballing there. Also are you doing all the work yourself or paying someone else to do it? If you're paying someone else expect to spent a few k more.
RedLeader289
May 28, 2019 01:47 PM
LT1Formula
Oct 8, 2015 08:34 PM
