305 help PLEASE
Old Mar 1, 2008 | 09:30 AM
GoodlookinRS's Avatar
Car: 1986 corvette Z51
Transmission: doug nash 4+3 speed
Axle/Gears: 3:42 posi
305 help PLEASE
Ok i have a 305 tbi in my 90 camaro and when it sits for like 5-6 hrs it runs really rich. When i start it it will run at 1300rpms untill it gets warm. But i love when it runs like that becase it feels like it has some power to it. So how can i always keep it running rich or at 1300-1500rpms all the time?
Would a chip do that for me or not?
Old Mar 1, 2008 | 11:36 AM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
Re: 305 help PLEASE
yah all engines run real rich at startup. Have to due to the low temp the engine is at while at startup.
anyways your car should never run better in open loop than it does in closed loop. (open loop is your startup well more complicaated than that but, it's before your at operating temp). Also by better go a little more in depth with that if you will so i can fully understand your thoughts. I'm not trying to be a p.i.t.a. but, i know mine is noisy at startup and noise to most means power in the sotp so it's more a mind thing than anything else. If yours runs better in open loop i'd be a little more worried at y then trying to make it run like that all the time. Also gm made these cars from factory run rediculously rich anyways usually 11 to 1 or thereabouts for a safety factor.
but, in answer to your qestion you could force your car to stay in open loop but, i wouldn't reccomend it unless it's like a track only car, also yes a chip could do what you want but, it would need to be custom not a mail order pos sorta deal.
pjsparts
Oct 29, 2025 06:39 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
rsrookie
Sep 5, 2015 07:08 PM
Formula_88AE
Sep 3, 2015 01:47 PM
