LT1 heads?
Old Mar 2, 2008 | 04:00 PM
TelinskiA's Avatar
LT1 heads?
i have a set of roller rockers off a I-gen block will they fit an LT1?
Old Mar 2, 2008 | 05:50 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: LT1 heads?
Lt1's need self aligning rockers IIRC. So no. Not unless you use guideplates on the LT1 heads.
Old Mar 2, 2008 | 07:37 PM
TelinskiA's Avatar
Re: LT1 heads?
but if i have guide plates the first gen rockers will work?
Old Mar 3, 2008 | 07:19 AM
Brian Esser's Avatar
Car: 1996 Chevrolet S10
Engine: 350 LT1
Transmission: TH350
Axle/Gears: 3.08:1
Re: LT1 heads?
Yes but you may run into issue with the valve covers. I think the self aligning were also narrower?
Old Mar 3, 2008 | 06:22 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: LT1 heads?
Which rockers are they? What motor were they on before - one with centerbolt heads (same style valve cover as the LT1) or perimiter bolt valve covers?
Also, yes the LT1 does use self aligning rockers, so you'll need to use either self aligning roller rockers (they will have a 'lip' on either side of the roller tip where it contacts the valve so it can't slide off if it is a self-aligning rocker) or have guide plates installed under the rocker studs.
Aluminum head LT1s already have screw-in studs, so I'm not sure if they would need to be machined for guideplates, or if it would be ok to just stick them under the studs and leave the heads alone?
Old Mar 3, 2008 | 10:39 PM
Engine: 350 LT1
Transmission: TH350
Axle/Gears: 3.08:1
Re: LT1 heads?
Not sure if the stock screw in rocker studs have enough threaded shank to let them use guide plates? Even if they aren't, a good set isn't that much anyways.
Old Mar 4, 2008 | 06:10 PM
Air_Adam's Avatar
Re: LT1 heads?
I've never taken a stud out of my LT1, so I couldn't say. But a good set of ARP studs is was around $60 last time I got a set. Good investment if you are using valve springs stiff enough to require roller rockers.
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
midge54
Sep 2, 2015 06:27 PM
midge54
Aug 29, 2015 09:51 PM
Redwhisper
Aug 26, 2015 05:02 PM
