help with MAF to Speed density swap
Old Mar 2, 2008 | 05:18 PM
bmfIROC-Z's Avatar
help with MAF to Speed density conversion
My $300 granatelli MAF sensor just took a crap so im done with MAF,anyway i just read the article about this subject and it said something about needing a EPROM programmer for VSS change and VATS disable and ive never done any kind of programming before so im a little intimidated and i was just wondering if i get the wiring harness,ECM,memcal,knock sensor,and MAPsensor off of a 90-92 305 tpi car could i swap it out without any programming?if not whats the cheapest or easiest way to go about this and how much is a EPROM programmer and where do you get one?if somebody would help a brother out and explain this a little more in depth i would really appreciate it,thanks in advance,Joe
Old Mar 2, 2008 | 07:53 PM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Re: help with MAF to Speed density conversion
The VSS change is because of your mechanical speedo in the dash. If you upgrade the entire dash to a 90-92 car also, that would eliminate the need for the VSS change.
The VATS disable is because your car doesn't have VATS. If you grab the VATS box, wiring, steering column and keys (as well as all the door/trunk locks) you can eliminate the VATS disable.
It's alot easier to get a Programmer, or a Ostrich emulator from www.moates.net. With the list of engine mods you have, you'll need to tune the speed density system anyway, so why fight it?
Old Mar 2, 2008 | 10:04 PM
bmfIROC-Z's Avatar
ah i see, will i need any adapters or programs for the programmer or emmulator?what would be best to use the programmer or the emmulator?or does it matter?will i need the full harness from a sd car or just the ecm connectors?thanks for the help.
Old Mar 3, 2008 | 09:13 AM
85MikeTPI's Avatar
If you get the Ostrich, all you need is a USB port on a computer, and the TunerProRT software (very reasonable cost). It's more expensive than a programmer, but much easier to work with.
If you follow the tech article on the harness re-pinning, you don't need a harness from a SD car.
Old Mar 3, 2008 | 11:17 PM
bmfIROC-Z's Avatar
What part number for the memcal for a 305?or is it the same as 350?and will i need different runners without the cold start?thanks again ,Joe
Steve78LT
Feb 24, 2016 12:15 AM
Keith5
Aug 27, 2015 04:37 PM
nuggie
Aug 25, 2015 01:27 PM
InfinityShade
Aug 22, 2015 08:00 PM
86Base
Aug 8, 2015 01:34 PM
