Main bolt torque question
Old Mar 8, 2008 | 11:54 AM
82CamaroZ28's Avatar
Car: 1982 Camaro Z28
Engine: Self-built 350
Transmission: Pro-Built 700r4 w/2800 Vigilante
Axle/Gears: Eaton 3.73 w/Moser axles
I am using ARP (180,000 PSI Tensile Strength) main bolts on my new engine along with ARP Moly lube. I'm trying to figure out what my torque values need to be. According to the ARP Torque Recommendations chart (attached), 58 ft/lbs is the value to achieve optimum preload for a 7/16-14 bolt. I'm guessing that I should use this value for the inner bolts (4 bolt main), but what should I use for a torque value for the outer bolts?
Old Mar 8, 2008 | 12:08 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Why would it be different?
Old Mar 8, 2008 | 12:16 PM
Re: Main bolt torque question
I just assumed it would be less since the specs using stock bolts are 70 ft/lbs for the inners and 65 ft/lbs for the outers.
Old Mar 9, 2008 | 07:47 AM
Pat Hall's Avatar
Just torque them to the factory specs and you'll be fine. Considering the ARP bolts are stronger than stock, I'd certainly torque them to 70/65 instead of a mere 58 ft. lbs.
84z96L31vortec
Aug 20, 2017 12:16 AM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
