starting problem
Car: 1992 Camaro RS
Engine: 305 TBI
starting problem
my camaros been having a problem the problem started some time after its been sitting for a few months but now after its been running for a bit and u turn it off when u try to turn it back on it will just die unless u hold the gas down a bit but when u lett off it still dies it will do this a couple of times than it will run and its also been goin thro gas really bad like it went thro about a 1/4 tank in less than 10 miles. what could the problem b iv been trying to find out befor i start blowin money on things i dont need
Car: currently a 91 G92.
Engine: 305TPI
Transmission: Borg Warner WC 5 speed
Re: starting problem
The going through gas part is the part I am not sure about. Often times when a car sits for more than a couple of months without fuel stabilizer in the gas, varnishes tend to build up and clog the fuel delivery system. First try to replace the fuel filter and replace the old gas with good gas. Run some fuel injector cleaner through the fuel system and see if that helps any. Use the concentrated stuff. If that doesn't improve your situation, I would start by taking fuel pressure readings and go from there.
Car: 1992 Camaro RS
Engine: 305 TBI
Car: 1992 Camaro RS
Engine: 305 TBI
dosw enyone else know what the problem might be?
i also took a quick video of what its been doing
http://s148.photobucket.com/albums/s...t=SMOV0067.flv
Engine: 305TPI
Change the fuel filter. It will only help. Also check the fuel pressure. you might have a finicky fuel pressure regulator or a fuel pump relay.
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
clean the iac ill bet its really dirty causing it to stick in the open position, thus getting too much air causing the stall, remove it and the bottom plate and clean with carb or brake cleaner, later jimmy
Car: 1992 Camaro RS
Engine: 305 TBI
ok well i havent had time to try eny of the thing u guys has told me to yet because of school so ill probley get to it this weekend but i was just think about what could cause this because it seems odd to me that it onley has the problem starting when u let it sit for about 30 min or more after its been running and i was also thinking because it gose thro gas like crazy and u can smell it in the exhaust do i need a new o2 sensor and would that have enything to do with the way its starting dont know just a thought let me know what u guys think
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
im not sure if the O2 sensor would fix the gas usage....do you know if your maintaining spark? That might be another problem ive seen. Try that new filter and see how she does, it might fix it
Engine: 305TPI
Car: 1992 Camaro RS
Engine: 305 TBI
Car: 1992 Camaro RS
Engine: 305 TBI
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
fuel economy yes, but that doesnt explain the smell, is it like a rich exhaust smell or a oh sh** my tanks has a leak smell?
Car: 1992 Camaro RS
Engine: 305 TBI
Car: 1992 Camaro RS
Engine: 305 TBI
ok so now im thinking that it is running rich cause its smoking abit more than usal and it smell and im goin thro gas hella fast but i dont get how it would runn rich with out eny dash lights comin on and would it running rich have enything to do with it dieing.and i guess i do get a light when it dies but if it was running rich wouldnt it have the code all the time?idont really know whats goin on so help me out cause i wana get it running good this weekend
92camaroJoe
Aug 13, 2015 06:07 AM
