rebuilding the 305
Car: '82 formula clone, 95 saab 900se
Engine: 350 vortec'd tbi, 2.0L turbo
Transmission: 700r4, 5 spd
Axle/Gears: 10 bolt 2.77 open
rebuilding the 305
i know everyone says why spend the money on the 305 when you can get a 350 just as cheap. i don't care, i've already got it torn down and cleaned up. so please don't even mention a 350.
i'm trying to keep this as low budget as possible, i have a set of 305 vortec heads i'll be using but not changing the cam unless someone has another lt1 cam.
i haven't measured the cylinders yet but what are the chances that i can get away with no machine work? the engine didn't really have a lot of miles on it and there wasn't any bad wear on anything, but if it is out of spec can i just get oversize rings and not need oversize pistons?
Transmission: 4L80E/4L80E
If the cylinders are out of spec, you need to have them overbored. You can't put oversize pistons or rings in a worn standard cylinder. You might be able to put file-to-fit rings in, but if the cylinders are out of spec, they won't seal properly, anyway.
There is a reason everyone says to get a 350 instead of rebuilding a 305. You saying you don't want to hear it doesn't make it untrue.
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
Re: rebuilding the 305
First of all, a 700r4 is not a 5 speed! It sounds to me that your after a cheap rebuild, that's not going to give you any more performance over stock. The best you can hope for is a re-built 305 that will keep your car on the road.
If you want performance, do it right. Don't try shortcuts and expect something out of nothing. There's an old saying pal, "there's no substistute for cubic inches". ( notice I didn't mention the other motor).
Take your sabe 900se somewhere else!
Take your sabe 900se somewhere else! Last edited by sqzbox; Mar 15, 2008 at 01:49 AM. Reason: Automerged Doublepost
Take your sabe 900se somewhere else! Thread Starter
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally Posted by johnnyboy
i haven't measured the cylinders yet but what are the chances that i can get away with no machine work? the engine didn't really have a lot of miles on it and there wasn't any bad wear on anything, but if it is out of spec....
no i didn't get a chance to do a compression check, it was in a parts car that i had bought, the body was real rough but it ran well, i'm really just looking to freshen it up. thanks for the input
Car: '70 Bronco, '91 Firebird, '03 Chevy
Engine: roller 302, 350 TB, stock 6.0
Transmission: NP435 Granny 4 spd, 700R4, 4L80E
Axle/Gears: 4.56 spool, 2.73 open, 4.10 broken
I did a $200 O'reilly re-build on my Blue Oval five liter, just a quick (not very effective) hone on it with a hand drill & a borrowed honing tool.. That block had a LOT of wear & a pretty obvious ring ridge. I just threw some new bearings & rings at it & it worked great for quite a while... The reason that motor died was from the 4-bbl I put on it running too lean at high RPM torching a piston. So if a Ford motor can do it yours should be able to also (right everybody?)
someone972
Aug 30, 2015 12:52 AM
