timing chain slack
Old Mar 9, 2008 | 08:26 PM
drperformance's Avatar
Car: 1987 firebird
Engine: 1995 lt1 383
Transmission: 4l60e
Axle/Gears: moser 9" with 3.70
timing chain slack
How much timing chain slack is ok?
I just pulled my timing cover and measured movement somewhere around 5/8" midway between the cam and crank gears. This is a newly professionally built LT1 with less then 500 miles (hard miles), and I beilieve that it is a cloyes billit steel rollor style with 9 crank keyways (one for a normal chevy 350, I deleted the gear driven water pump). Should I be concerned? Is this too much play?
Old Mar 10, 2008 | 08:46 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
Re: timing chain slack
if that is happening in 500 miles put a gear drive in it
Old Mar 10, 2008 | 11:32 AM
Car: 1987 firebird
Transmission: 4l60e
gear drive = false engine knock, and on a EFI LT1 with a knock sensor would cause timing issues.
This 5/8" was measured deflection in between the cam and crank gear, and I do not know how many degrees of slop it turns into at the crank or cam gear.
Does this seem bad for 500 miles?
Vintageracer
Jan 10, 2020 05:33 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
MY87LT
Aug 17, 2015 08:43 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
