2nd ring gap
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
2nd ring gap
What's the convention for the ring gap of the second ring?
From my bible, (David Vizards book) he mentions gapping the second ring slightly larger than the top ring. Now i've opened up my top ring gap considerably (future nitrous use), but i'm unsure about the second. I know it won't be seeing the heat that the top one will, but should I leave it gapped tighter than the top ring?
Just wondering if there was a logical convention one way or the other.
Re: 2nd ring gap
Used to be, they were left with less gap than the top ring, precisely because they don't expand as much; but the conventional wisdom nowadays is to leave the 2nd gap slightly wider than the top one. Not a whole lot, maybe 15-20% wider. No matter what the top gap is.
Car: 1982 Trans-Am
Re: 2nd ring gap
Hmm, ok, fair enough. I'm doing the top ring at .028 or so, so I might go up to .035" or thereabouts then.
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Re: 2nd ring gap
I guess a little more blowby is ok for insurance.Speedomotive guidelines:
Top Rings (ductile iron, 4" bore)
Supercharged
Nitromethane .022 - .024"
Alcohol .018 - .020"
Gasoline .022 - .024"
Normally Aspirated - Gasoline
Street, Moderate Performance .016 - .018"
Drag Racing, Oval Track .018 - .020"
Nitrous Oxide - Street .024 - .026"
Nitrous Oxide - Drag .032 - .034"
2nd Rings (plain iron, 4" bore)
Supercharged
Nitromethane .014 - .016"
Alcohol .012 - .014"
Gasoline .012 - .014"
Street, Moderate Performance .010 - .012"
Oval Track .012 - .014"
Pro Stock, Comp. .012 - .014"
Nitrous Oxide - Street .018 - .020"
Nitrous Oxide - Drag .024 - .026"
Car: 1982 Trans-Am
Re: 2nd ring gap
I was looking at KB's;
http://kb-silvolite.com/article.php?action=read&A_id=56
I don't have KB pistons, but their logic is sound. The excess gap isn't going to hurt anything (rings not sealing against walls would cause it to suck up oil, but a slightly larger gap is a microscopic change).
I wanted all the insurance I could get that I won't butt the rings together. .030" is NEVER going to butt together, even if I do grow the grapes to shoot that 250HP pill.
Ok, so your reasoning for a tighter second gap is ? It won't get as hot, so trap as much combustion gas as possible?
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
Re: 2nd ring gap
hmm? well Ive got KB's and I gapped mine .035 it called for .033 with my bore size for nitrous use so I went alittle bigger just to play it safe. Im wondering now if thats where all my oil is going? I dont get any blow by out the exhaust that I can see but the oil is going somewhere. I mean like alot!
Engine: 350 4BBL
Re: 2nd ring gap
Let's revisit the stock spec just for fun. Top ring: .010-.020 ,service limit .030 .
Second ring: .010-.025 ,service limit .035 .
For Wishmaster, Speedomotive: "The second ring is primarily an oil control device. If the top ring is doing the job, the second ring will see fairly limited combustion pressure."
My reasoning is this: I know that nitrous will mandate a wide gap on the top ring, the only thing left from us building a brand-new "worn-out" engine is the second ring. So let's make it's gap even bigger?
Remember, the engine will also be run without nitrous a lot too.
Ring gap:
.010 = new
.020 = 80k miles
.035+ = 200k miles
Re: 2nd ring gap
Ring and piston designs and materials have changed, since alot of those "old standby" type books were written. Their details sometimes are obsolete as a result. Doesn't mean they're "wrong"; it just means that what they say, doesn't apply to the newer materials and techniques.
Used to be, the 2 (or more) top rings were both considered to be part of the compression seal, and the single "scraper" ring assembly took care of oil. However, better top rings seem to handle the combustion issue adequately all by themselves, and 2nd rings are now designed for improved oil control (this being, obviously, an emissions issue).
So, it seems that nowadays, it is considered better to use the wider 2nd ring gap such that any compression leakage that DOES occur past the first ring, can easily escape from that space between the 1st & 2nd rings; and the 2nd ring can then do its oil duty without interference from combustion pressure.
At least, that's how I'm understanding what I've been seeing.
Car: 1982 Trans-Am
Re: 2nd ring gap
Well see I don't get that. I can understand the rings wearing on the outside (sealing area), but I wouldn't think their gap would wear out much and become wider. I think losing the crosshatch on the cylinders would cause more oil consumption vs ring gap. According to that nifty chart on KB's site, they tested an engine with "normal" gap (KB specs), and .080" !!!! Oil consumption was barely effected.
.080" gap is about what you get when you use rings meant for an extra oversize bore, ie. one size up, .040" rings in a .030" bore. I'm taking all my info here from KB as gospel, and very little from personal experience.
Alright, so sofa you say that the idea behind gapping the second ring wider is to help the pressure relieve, this is the pressure between the rings. This pressure would help seat the rings though wouldn't it?
Hmm, i'm torn here. I think i'll just gap them identically, and see how it goes. My last build of this engine guzzled oil (or leaked it moreso I think). So this time i'm going to break it in LIKE I STOLE IT. Then i'll post back on how much oil it drinks with .030" top and 2nd gaps
Thanks guys!
Thanks guys!
Guest
Posts: n/a
Re: 2nd ring gap
The quoted ring gap service limits arent to determine if the gap is too big to let the ring do its job, but rather that the ring has worn down enough from scraping the walls that the gap increased significantly and its lost tension as well.
Car: 1982 Trans-Am
Re: 2nd ring gap
Well... haha, we can't really compare gapless rings here eh? I'd love to do gapless though, best of both worlds.
LT1Formula
Oct 8, 2015 08:34 PM
