Positive Stop Valve Seals
Old Mar 11, 2008 | 06:37 PM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
I have a set or World Heads that are in need of Valve Seals. The OD of the machined Valve Guide measures .538.
All of the Positive Stop Seals that I am finding are made for .530/.531 Guide OD's.
I have never installed Positive Stop Seals, so I don't know if these would fit or not. Ideas?
Old Mar 11, 2008 | 07:13 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: Positive Stop Valve Seals
sig pic is WAY too large, please cut it by 80% or so. thanks.
As for that, I'm pretty sure that they would bolt on no issues, we're talking .007 of an inch. Worst case is call a local speed shop and have them machine the guide down that slight amount. What seals did world use on their assembled heads initially?
Old Mar 11, 2008 | 07:15 PM
Yes they should work.
Give them a call... www.worldcastings.com
Old Mar 12, 2008 | 11:57 AM
mnorton's Avatar
Engine: 305 LB9 TPI
World used Umbrella Seals that were the same OD as the Spring Dampers ID so they got chewed up in about 1K mi. Really pissed me off. World didn't want to warranty the issue. Their customer service sucks. So now I am looking into Valve Seal options.
Old Mar 12, 2008 | 12:49 PM
xpndbl3's Avatar
Car: 1984 Z28
call a local speed shop/machine shop and just have them put in valve seals and if any guide work is needed it'll be done cheaply. I think I only paid $30 for a pair of heads to get the guides cut for positive type valve seals. Really though with .007 of difference I think the comp white ones in the .53X range should be fine, just make sure not to gall them while installing, use the plastic installer that slips over the end of the valve.
1992 Trans Am
May 10, 2023 07:19 PM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:18 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
g.l.mos
Aug 22, 2015 12:02 AM
86White_T/A305
Aug 17, 2015 12:16 AM
