just installed slp runners and car ideles crazy high
Car: 91 z28, 92 rs
Engine: 350 zz4, 305 tbi :(
i just installed slp runners the car idles crazy high like 5000 rpms? what the heck did i do wrong
Car: 87 Trans Am GTA
Re: just installed slp runners and car ideles crazy high
You probably had the same problem as me, only I caught mine before it could potentially turn into a problem. On my SLP runners, I assembled the whole TPI on my workbench to make sure everything fit and all my port work matched up. Lo, and behold, I noticed some light peeking through at some spots where the runners mate with the plneum even with the gaskets on. Turns out my flanges were warped ever so slightly. Enough that it was causing a leak, but you'd never be able to tell up close. had I thrown it on my car, my car would be revving high just like yours does.
Two options, you can either have your runners milled down or do what I did, apply RTV to both sides of the gasket to seal everything up. It'll make for a real fun job when I need to reomve everything next time around, but at least I got no leaks. I hope this helps.
Axle/Gears: '01 3.42 10 bolt
5000rpms??????? are you sure about that? 5000rpms is almost the equivalent of having the gas pedal pushed to the floor.....or no throttle body.
check your throttle body blades to see if they are hanging oped due to a mis-aligned cable.
Car: 91 Z/28, 89 RS Race Car
Engine: 305 stock / ZZ4 AFR 195 9.7:1
Transmission: T5 / t10 / Jerico
Axle/Gears: 10blt w 3.42, 9 in w /3.80 DL
Make sure the runners are not crossed. I think there is a right and a left side.
You have a vacume leak.
Linson
Aug 21, 2015 02:12 PM
