Axle cover Bolt torque
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Does anyone have any specs on a 1999 LS1 rear axle cover? I'm looking at a 3rd gen book and it went from 30 ft lbs, then in like 87+ it says 20 ft lbs. Does this apply to 4th gen axles? I did a search with no results...
Thanks in advance for your response.
Re: Axle cover Bolt torque
Torque
Some.
Torque goes with hardware size.
20 ft-lbs is fine.
Tight enough they won't fall out, not so tight you break them.
thank you, i have a breaking bolt syndrom most of the time, i just wanted to check before i put any fluid in. Thanks again!
ambainb
Apr 25, 2016 09:21 PM
red90IROCls1
Aug 25, 2015 06:56 AM
