Oil Pressure Q's?!?!?!
Old Mar 13, 2008 | 07:19 PM
mbolte's Avatar
Car: 1987 Camaro
Engine: 350 dart ies comp cam intake carb
Transmission: 700 r4, shift kit, 2400 stall
Axle/Gears: 10 bolt stock
hey all,
well my car is doing some wierd things with the oil pressure. The gauge is new because I replaced it with one when I first noticed it. The gauge is a sunpro mechanical the stock one doesn't work. The problem is when I am at full throttle the oil pressure actually drops. And sometimes when I come to a stop light the gauge reads 0 but I give it a little rev and it bumps back up. When I look at the clear line it has a lot of air bubbles in it. The motor has less then 20,000 miles on it. Also when I put in the gauge i didnt replaced the line...
What do you guys think???
Old Mar 13, 2008 | 08:21 PM
Badass355ciz28's Avatar
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
Re: Oil Pressure Q's?!?!?!
you need to crack the fitting on the line a little to bleed out the air bubbles...have someone disconnect the coil and crank it over while the line is cracked open till the air bubbles are gone then tighten it back up and reconnect the coil. then see where your at when you start it up.
Old Mar 13, 2008 | 08:32 PM
mbolte's Avatar
Car: 1987 Camaro
ok ill give that a try and i will let you know what happens
thanks man!
Old Mar 13, 2008 | 08:34 PM
did this do it before with any other guage?
Old Mar 13, 2008 | 08:36 PM
mbolte's Avatar
Car: 1987 Camaro
it actually started doing it with the other gauge but i did a head swap and had the line unhooked then
83 Crossfire TA
Jan 3, 2016 01:26 PM
angel2794
Sep 8, 2015 06:22 PM
Strick1
Sep 4, 2015 07:11 AM
solocus
Sep 2, 2015 12:14 PM
