oil from valve cover
Old Mar 13, 2008 | 10:19 PM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
oil from valve cover. head gasket? valve gasket
Delete
Old Mar 13, 2008 | 10:29 PM
Parasoth's Avatar
Car: 99 Z28 / 68 Skylark
Engine: LS1 / 455
Re: oil from valve cover
Maybe a valve cover gasket? '.'
Old Mar 13, 2008 | 10:30 PM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
Im hoping its something that simple. What would you think worst case senario?
Old Mar 13, 2008 | 10:32 PM
TheRealBlkBird's Avatar
Car: Pontiacs, Jeeps
The valve cover gasket.
Mines doing the same thing. You have center bolt valve covers, correct? Luckily I dont drive mine right now.
Old Mar 13, 2008 | 10:46 PM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
Felete
Old Mar 13, 2008 | 10:53 PM
Well sometimes my coolant reservoir is low and I haft to refill it, but if I take the radiator cap off it is always full in there, but the reservoir is new and I cant find a leak in it anywhere, so im concerned this could have something to do with it, but doesnt make since with the radiator always being full when i check.
They are the stock covers.
So what, you're thinking the head might be cracked or a bad head gasket? You would probably have coolant running out all over the header too then. Coolant is thinner (and under pressure) so it would find its way out easier then oil. Im pretty confident its just the valve cover gasket. Dont sweat it, get a good night's sleep and check it out in the morning. The most obvious answer(valve cover gasket) is usually the correct one.
Old Mar 13, 2008 | 11:05 PM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
Delete
Old Mar 14, 2008 | 08:32 PM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
Delete
Old Mar 14, 2008 | 11:29 PM
That is odd. Problems rarely fix themselves.
Old Mar 14, 2008 | 11:35 PM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
Definetly. I still think something is up, just odd it wouldnt do it again. I dont think it fixed itself at all.
Old Mar 15, 2008 | 02:04 PM
billymac49's Avatar
Car: 88 IROC
Engine: 5.0 tpi
Transmission: 700 r4
Re: oil from valve cover. head gasket? valve gasket
white smoke out the pipe usually means coolant getting into the combustion chamber. if you have to add coolant and don't see any leaks you are probally burning it out the pipe. intake/head gasket, cracked/warped head or intake?
Old Mar 15, 2008 | 03:40 PM
Let us know what it is/was.
Old Mar 15, 2008 | 04:35 PM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
It only white smokes on start up, doesnt after that, but still possible I guess.
I will let you know as soon as I know.
86CamaroNJ
Mar 26, 2010 04:36 PM
camaroguy21
Jul 5, 2006 12:49 PM
ChevyRacer
Aug 31, 2005 09:54 PM
ladyfirebird
Aug 3, 2005 09:38 AM
