can i use a 1 wire on this setup?
Old Mar 14, 2008 | 08:52 PM
jay_d's Avatar
Car: 84 z28
Engine: 355
Transmission: TH350
Axle/Gears: one wheel peel
alright fellers, i have a 83 z with 89ish serp setup on it.......ive got my car running and driving and am ready to get it off the battery charger, how can i wire up the 89 alternator in the 83 car? or wouldnt a one wire just be the easiest? only problem i can think of id the 1 wire is a bigger alternator and wont fit the brackets
Old Mar 15, 2008 | 09:32 AM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Re: can i use a 1 wire on this setup?
The one-wire alternator would be a big step backwards and it doesn't make enough amps. All you will need is a pigtail plug that goes in the '89 alternator.
If you can get that from the donor car, we can tell you which wires to hook where.
Terrell351
Jun 13, 2021 01:13 PM
Street Lethal
Apr 30, 2019 12:14 PM
stalkier
Dec 6, 2015 11:25 PM
nuggie
Aug 25, 2015 01:27 PM
Street Lethal
Aug 13, 2015 08:28 PM
