What Gap ?
Old Mar 15, 2008 | 01:39 AM
gen 1's Avatar
Car: 1992 b4c 1le
Engine: 5.7
Transmission: auto
Axle/Gears: 3:23
What Gap ?
Hello..I did a search with no help.. So please help if you can. I have a "stock" 1992 L98 camaro. I would like to know if i put the CR45TS spark plugs in the car what do i gap them at? Autozone says .50 another one says .35 please help i don't want to do this again for a while this info make me
Old Mar 15, 2008 | 01:59 AM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
Re: What Gap ?
Dude, (I call you that because you haven't checked the engine spec's tag under your hood) It will give you the correct gap for your plugs. Get a magnifying glass out and go over it real good. Not only will it give your the correct plug application, but it will give you the plug gap also. (unless some ding dong painted over it).
Old Mar 15, 2008 | 02:15 AM
gen 1's Avatar
Car: 1992 b4c 1le
Engine: 5.7
Transmission: auto
Axle/Gears: 3:23
Re: What Gap ?
Thanks, I for got about that little sticker.. it shows .035 "But" Is this for the R43TS or the new CR45TS ??
Old Mar 15, 2008 | 02:21 AM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Re: What Gap ?
New cr45ts? Is that a replacement for the r45ts? If so, go with the original plug gap on the sticker!
Old Mar 15, 2008 | 02:40 AM
gen 1's Avatar
Car: 1992 b4c 1le
Engine: 5.7
Transmission: auto
Axle/Gears: 3:23
Re: What Gap ?
I thought the 43 is what the car came with from the factory??? I thought i read that some where.. Did i just miss read? Thanks
Old Mar 15, 2008 | 02:52 AM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Re: What Gap ?
The "C" in CR43TS denotes, copper core in the plug. Go with the gap on your sticker. Copper is a good conducter of electricity and is desined to move it faster.
Old Mar 15, 2008 | 02:55 AM
gen 1's Avatar
Car: 1992 b4c 1le
Engine: 5.7
Transmission: auto
Axle/Gears: 3:23
Re: What Gap ?
Thank you !
diana227vegas
Jul 8, 2016 12:27 AM
thekurlyone
Sep 30, 2015 12:54 PM
roysatikas
Sep 22, 2015 08:15 PM
Thornburg
Sep 1, 2015 03:39 AM
Dialed_In
Aug 20, 2015 01:45 PM
