Is there such thing as an idle air control on my car?
Old Mar 16, 2008 | 07:34 PM
spiderhole's Avatar
Car: 86 z28 LG4 305ci
Engine: LG4 305ci
If so, where would it be located? I have the 4 barrel setup. I've dug through the shop manual, but I am still the complete newby. The car is idling high. Ive got it running well all things equal otheriwise. The high idle is the last thing to knock out on the engine side.
Old Mar 16, 2008 | 08:37 PM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
Re: Is there such thing as an idle air control on my car?
.. idle adjustment screw on the carb.. 1/4 turn a at a time.. home this helps
Old Mar 16, 2008 | 08:41 PM
spiderhole's Avatar
Engine: LG4 305ci
not that the adjustment screw didn't cross my mind, by this car was completely stock. It just seems too obvious. I don't want to throw anything out of wack. What is the correct idle when the car is warm? Isn't there more than one adjustment screw also?
Old Mar 16, 2008 | 09:49 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
"Correct" idle with a carb is pretty much where you prefer it to be, but generally stock engines are happy with around 750-900 in P or N, and around 600-700 in Drive.
Old Mar 16, 2008 | 09:53 PM
spiderhole's Avatar
Engine: LG4 305ci
how do I get it there?
Old Mar 16, 2008 | 10:34 PM
slow_90firebird's Avatar
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
My buddies LG4 loves about 700-750RPM in P/N, and when he puts it in drive it is exactly 500rpm. Anything higher than that, the exhaust sounds weird, and when you put it in Drive, it kinda slamms the clutches just a little where it is noticible.
Old Mar 17, 2008 | 06:15 AM
spiderhole's Avatar
Engine: LG4 305ci
Old Mar 17, 2008 | 07:24 PM
Air_Adam's Avatar
Start the car, let it fully warm up so that the choke/fast idle comes off, then adjust the screw with it running, untill it idles within the range I mentioned in my post above.
All the idle adjustment screw is, is a stop-screw for the throttle lever on the carb. Screw it in = higher idle, screw it out = lower idle. Just make adjustments about 1/4 turn or so at a time, give it a quick rev just so it can 'reset' itself and see where it idles, and keep adjusting as necessary. Its pretty simple and straightforward.
Old Mar 17, 2008 | 07:27 PM
Air_Adam's Avatar
This is the screw you are looking for:
Attached Thumbnails Is there such thing as an idle air control on my car?-carb.jpg
Old Mar 17, 2008 | 07:42 PM
spiderhole's Avatar
Engine: LG4 305ci
By adjusting that, am I messing with the rich lean mixture at all? I don't wont to foul plugs, or worse. I am scared of making adjustments on my carb, because I fundementally don't understand how it works completely. The car starts up wonderfully right now. Everything is great except the high idle. I will try it, and take notes on how many quarter increments I back it out in case it starts acting funny. My main fear is always messing something up. I am on my own (save the advice I've been getting from this board).
Old Mar 17, 2008 | 09:15 PM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
It only adjust the idle speed. There is other screws for the a/f. its not hard.
Old Mar 18, 2008 | 08:33 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Look real close at the screw end (opposite the turning slot), and make sure it is touching the stop. Sometimes they will hang open a little bit from something else.
Looking at the turning slot, counterclockwise, out should slow idle.
Clockwise, in should raise the idle speed.
Count your 1/4 turns, a little turn should make a difference.
Ghettobird52
Jul 5, 2024 11:18 PM
specialized
Jun 18, 2022 09:26 AM
Wade787b
Sep 29, 2015 01:15 PM
kyleb24
Aug 15, 2015 08:24 AM
