Best place to jack up a 1987 GTA
Old Mar 19, 2008 | 02:29 AM
Spitzfiya's Avatar
Where should i be putting the jack under to work on the front end?
I have no clue whats solid and whats not...bad experience with my Firebird S/E
Old Mar 19, 2008 | 09:29 AM
zacharyhorn's Avatar
Car: 91 Firebird
Engine: Turbo 355
Axle/Gears: 3.73:1 7.625" 10 Bolt
Re: Best place to jack up a 1987 GTA
Well I personally use my subframe connectors, then slide the jack stands under the subframe. For you, you could jack on either side subframe or use the crossmember in the front of the car. You could put your jack stands under the lower control arms on the bushing, or use the sub frames.
Old Mar 19, 2008 | 12:08 PM
KamikazeIroccy's Avatar
Car: '87 Iroc-Z
Engine: 355cid Cam'd
Transmission: T5 Manual
Axle/Gears: Stock 9 Bolt
what about the rear on an '87 iroc
Spitzfiya's Avatar
doh' whats a sub frame and subframe connectors?
got a diagram or picture or anything lol
Old Mar 19, 2008 | 03:14 PM
Car: '87 Iroc-Z
from the factory we dont have subframe connectors, i dont know why he replied with that like everyone just has money to spend.
NEVER ***-U-ME
Old Mar 19, 2008 | 03:43 PM
Spitzfiya's Avatar
ummm then where am i supposed to jack p the car? I need help stat as im working on it tonight hehe
Old Mar 19, 2008 | 04:17 PM
87 formy's Avatar
Car: 87 formula
Engine: 5.0 TPI
You can jack it up by the K-member. It's a big metal piece that goes across the front of the car, just in front of the oil pan. I'd recommend sliding the jack in from one side of the car just in front of a wheel so you have room to move the handle up and down.
Old Mar 19, 2008 | 04:29 PM
Spitzfiya's Avatar
Ok thanks mang ..where on the k membr is the best spot? got like a diagram?
It takes me forever to do things cause i hate screwing up...lol...jacking up the car is not even half the battle...still have to figure out how to drain the fuel line on this car, drain radiator (Drain cap somewhere??? err where?), Get the friggin oil pan drain plug off (What the hell...even an air ractchet wont take it off...argg) and replace the fuel filter (where???)...replace thermostat (I have to dissasemble the air intake stuff to get it out, what if i loose soemthing or forget where it goes...scary)
I basically have no idea what im doing and all this "simple" stuff is taking soooooooooooooooooo long to do...I fail
Old Mar 19, 2008 | 05:05 PM
Car: '87 Iroc-Z
so what about the back?
Old Mar 20, 2008 | 11:58 AM
Spitzfiya's Avatar
Put the jack on the rear differential, thats where i put it last night when i change my fuel filter.
Also when i changed the oil I jacked the car up on the frame rail behind the front wheel on one side close to where it looks like two frame rails are joined togeather. Anyways when i started lifting with the jack on the spot the left tire dragged inward about 3 inches. I thought mabye cause it was sitting for awhile the suspension was just pulling it back into place...but then after i decided I should jack the car up under the front k member I noticed right infront of where i jacked up the car the fram rail looked a little indented and pinched.
Now i think its a coincidence because i was watching the jack as i was doing this and no damage was being done to anything.
But now I notice the left wheel is slightly bent outwards and pointing off to the left more.
Jacking up on the fram rails shouldn't have cause this....am i right?
Mabye just some play in the steering colum?
Old Mar 20, 2008 | 01:37 PM
ljnowell's Avatar
Thats normal suspension travel. That is the arc that the assembly follows during jounce and rebound. In short dont worry, as soon as you sit it down and move the car, it will all be where it belongs.
Old Mar 20, 2008 | 02:35 PM
TheRealBlkBird's Avatar
Car: Pontiacs, Jeeps
The only places I'll jack up the front of a third gen. is the engine crossmember or the lower control arms. Anywhere else, something will bend.
Old Mar 20, 2008 | 03:13 PM
Spitzfiya's Avatar
Ahh ok makes sense thanks dude just thought kinda wierd the left ones straight but the right ones off
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
TheTraut88
Sep 7, 2015 05:22 PM
Third_Gens_Rule
Sep 3, 2015 06:55 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
Thornburg
Aug 27, 2015 11:34 PM
