Splitfire plugs and wires
Old Mar 20, 2008 | 09:35 AM
goalieforlife's Avatar
Car: 1991 Pontiac Trans Am GTA
Engine: V8 305
Transmission: Automatic Transmission
Are these good plugs and wires? Does anyone here have them?
Old Mar 20, 2008 | 09:54 AM
Re: Splitfire plugs and wires
No. The plugs especially are garbage, and the wires are over-priced gimmicks.
Use AC/Delco plugs. If you REALLY want to bite off, use the Rapid-Fires. Avoid the "gimmick" plugs like Splitfire, +4, etc.
I'd suggest these wires.
Old Mar 20, 2008 | 10:10 AM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Just out of curiosity, why those specifically? What do you think of MSD wires? My car could use some new wires since the originals are still on there. They seem to work ok, but they shocked the **** out of me the other day when I touched a plug wire boot on the cap.
I want something that fits like factory, but some color would be nice too. Looks like a complete pita job to change them, is it?
Old Mar 20, 2008 | 10:27 AM
The MSDs are OK, but cost more. THey seem a bit more physically fragile though.
Yeah if they shock you, then the electricity isn't staying inside the wire like it's supposed to.... not good. Sounds like it's time.
The Taylors are available in various colors...
http://www.taylorvertex.com/Products...rcatalog10.pdf
Changing them isn't too bad, except for running the driver's side ones to the plugs. But even that isn't too bad if you jack up the car and get them from underneath.
Old Mar 20, 2008 | 10:46 AM
SteelTownMadDog's Avatar
I agree with Sofakingdom. Don't waste money on gimmick plugs/wires.
I also use the Pro Series Taylors. They work great aren't that expensive. I have the Hot Oranges for obvious reasons.
Old Mar 20, 2008 | 10:48 AM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Gawd I thought we had progressed beyond this sort of thing after the smokey and the bandit car era.
I used to like "rolling my own" wires so that they fit right. Or do current replacement wire sets actually fit decently?
Old Mar 20, 2008 | 11:14 AM
Engine: V8 305
ok, i take it splitfires are junk. Thanks for the heads up
Old Mar 20, 2008 | 11:20 AM
Those are a "roll your own" type set. They come with the plug end on them, you put on the dist end.
They're not too bad if you take all the old ones off, start from the shortest ones (5 & 7) to the longest, number them at both ends, run them from the plugs to the dist by whatever routing you prefer, then put the dist ends on.
Old Mar 20, 2008 | 11:25 AM
Engine: V8 305
how about these.. http://store.summitracing.com/partde...38+4294756594++
Old Mar 20, 2008 | 11:45 AM
Engine: V8 305
with these plugs http://store.summitracing.com/partde...5&autoview=sku
Come to think of it, my car already has the NGK Iridiums in her that I bought last year. Would I be downsizing in plug performance if i buy the ACdelco rapidfires? Do I need to change the plugs every season?
Old Mar 20, 2008 | 01:55 PM
Engine: V8 305
bump
Old Mar 20, 2008 | 06:12 PM
ljnowell's Avatar
If you are already running the proper ngk plug, and they are in good shape, why would you change them? Dont replace what isnt broke.
Old Mar 20, 2008 | 06:56 PM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
leave splitfire and that other crap to the r*cers who expect a 30hp gain by going with them
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Brcharrelson
Aug 26, 2015 07:47 PM
litemupp
Southern California Area
Aug 23, 2015 10:09 PM
jbd1969
Aug 17, 2015 07:06 PM
Exxon Limited
Aug 9, 2015 08:13 PM
