Crankshaft Rotate Tool
Old Mar 21, 2008 | 10:09 AM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
What's a good tool to use in order to rotate the crankshaft by hand? And does the tool require removing the harmonic balancer...
I am going to replace my valve springs. LB9 engine is still mounted in the car.
Old Mar 21, 2008 | 10:12 AM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
Re: Crankshaft Rotate Tool
5/8 socket and a long handle ratchet if you leave the balancer on. they have sockets to fit the crank if no balancer is in place.
Old Mar 21, 2008 | 10:29 AM
DO NOT use the damper bolt to turn the crank, unless you just enjoy repairing broken bolts and stripped threads.
If the damper is installed, use one like this. If the damper is not installed, use one like this.
Note that the SUM of those 2 tools is less than the price of the Heli-Coil kit to fix a wasted crank; and the one is cheaper even than a new damper bolt. Some things simply aren't worth half-a$$ing.
Old Mar 21, 2008 | 11:14 AM
mnorton's Avatar
Engine: 305 LB9 TPI
Thanks Sofa! I'm on it!
Old Mar 21, 2008 | 06:43 PM
Oh god, I have never had a problem using that...go ahead buy the tool BE SAFE by all means
gta892000
Aug 11, 2019 11:16 AM
92projectcamaro
Dec 8, 2015 12:25 AM
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
Reid Fleming
Oct 10, 2015 09:56 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
