Stall Speed? Or Failing Transmission?
Hi!
Ok I was wondering if someone could tell me the difference between me having a failing transmission and a stall speed converter....
I have a 1982 Trans AM 305ci....
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Stall Speed? Or Failing Transmission?
It depends what it's doing. When in doubt, pull the pan to see if there's any hard parts in it.
Car: Pontiacs, Jeeps
I would'nt go with that, it sounds like your tranny's slipping to me. Certainly someone you know is a little more knowledgeable about cars and can help you? All it would take is one take off to tell you. There's really no mistaking the two.
most stall converters really dont act that way. Its sort of difficult to explain, but the dont actually feel like a slip. You described a textbook slip. Sounds like pressure bleedoff. Takes a second to build pressure. Possibly a poor pump also. Do you hear any odd noises? grinding, whirring, clunking?
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Pull the dip stick and smell the tranny fluid. Is it red or black?
Drop a post over at transmissions and drivetrains.
C409
Sep 1, 2015 03:42 PM
Eric-86sc
Aug 24, 2015 09:01 PM
