Shorter Belt - Bypass AC/Smog?
Old Mar 21, 2008 | 06:00 PM
Cam-aro's Avatar
Car: '91 Z28
Engine: L98 H/C/I - 400whp
Axle/Gears: Moser 12-Bolt(4:30 w/spool)
My smog pump lost a bolt and somehow has became mis-aligned, it bent or something. Anyway, I'm looking for a smog pump delete pulley... but also had a curious question. I haven't looked at the car hard enough to logical figure it out myself and I'm stuck at work for time being.
Could I keep the AC/Smog pump attached and just purchase a shorter belt and bypass the AC/Smog pulley's and run everything else properly?
Old Mar 21, 2008 | 06:23 PM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
Re: Shorter Belt - Bypass AC/Smog?
go to the homepage go in tech articles then to miscellanious modifications go down to deleting smog pump from serpentine belt setup,later jimmy
Old Mar 22, 2008 | 08:08 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
i did it to mine a couple of years ago . works great . i made a copy of the belt # and routing that i keep in the car . being a ret. mil.&civ. acft. mech. , plus a civ. pilot . prenative maint. is a must . do it right or don't do it .
Old Mar 23, 2008 | 10:48 AM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Just ditch the pump, don't worry about the delete pulley, reroute the belt and it takes a longer one, read the article listed above.
Old Mar 23, 2008 | 04:25 PM
92RS702's Avatar
Car: 92RS
Engine: 305= boat anchor
Axle/Gears: 4th gen 3.23
Forget the delete pulley like DartByu says just put a longer belt Goodyear part #4060967 will work fine,go to the home page and look at how to re route the belt.
Old Mar 23, 2008 | 04:44 PM
1985WS6transam's Avatar
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
Is there a way not to go tothe A/C also?? Right now I still have my A/C but later I might want to delete it... I already deleted my smog pump.
Old Apr 8, 2008 | 11:26 PM
topless89's Avatar
Car: 89 RS Convertible
Engine: 305 tbi
Transmission: 700R4,B&M friction,Transgo shiftkit
Axle/Gears: 2.73 LSD
i've got the same question. we've all read the tech on bypassing the smog pump, but can a short belt be used to run only the alt, water pump, and p/s pump? i usually don't use my ac but i don't want to remove a working system from my car. i looked at the routing, and i don't know if there is enough contact area on the water pump pulley. also it might be difficult to install with no tentioner.
Old Apr 9, 2008 | 06:51 AM
bigjay89gta's Avatar
Car: 89 GTA
You can make it work I did it once but you have to get a different upper coolant hose and you have you move you air intake up to keep it up off the belt. It isnt worth it just buy an A/C delete pulley. but I will see if I still have the part numbers laying around.
Jason
$750 L98
Feb 1, 2025 02:25 PM
sparks454
Interior Parts Wanted
Oct 18, 2015 03:18 PM
SRKLEGIN
Oct 12, 2015 07:28 AM
SRKLEGIN
Sep 30, 2015 07:19 PM
kitt23
Sep 26, 2015 07:48 PM
