Best time for plug change?
Old Mar 21, 2008 | 07:08 PM
goalieforlife's Avatar
Car: 1991 Pontiac Trans Am GTA
Engine: V8 305
Transmission: Automatic Transmission
I put ngk iridiums in my car last spring. i dunno if i should change them again this spring bc i am changing the plug wires.
Old Mar 21, 2008 | 07:26 PM
89importeater's Avatar
Car: 89 RS camaro
Engine: 454 swap in progress
Transmission: th400
Axle/Gears: 4.11
Re: Best time for plug change?
if they are fine then i say no need to but then again since you are their why not.
Old Mar 22, 2008 | 01:03 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Iridiums cost an arm and a leg. I'd check a few, and replace only if necessary.
Check the gap, the size of the electrode (which is always tiny on iridium plugs anyway...) and if they are gunked up or anything. If they look ok, just scrub them with a metal toothbrush and dip them in some solvent and put them back in.
Old Mar 22, 2008 | 12:38 PM
Engine: V8 305
I think i will leave them in and just change the plug wires.
thanks.
Old Mar 23, 2008 | 12:20 AM
mxcrazed's Avatar
Car: 87 firebird none soon
Engine: None
Transmission: none
Axle/Gears: 2.73 10 bolt
how do you like the iridiums I had one in my bike but it died. be careful I busted an electrode off one of those when I was trying to open up the gap a "hair" not a mm but oh well.
Old Mar 23, 2008 | 01:20 PM
Engine: V8 305
Actually I am not so sure. I think my wires are bad so I don't think I am getting the most out of my plugs.
eightsixseven
Dec 16, 2024 01:50 PM
Infested
May 22, 2018 11:56 PM
jharrison5
Aug 19, 2015 05:53 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
