305 tpi hesitates then takes off?
Old Mar 22, 2008 | 06:53 PM
digitalrebel's Avatar
Car: 90 IROC Z
Engine: 350 60 over
Transmission: t5 and 700r4
Axle/Gears: 3.08
Its a 89 firebird tpi and when I punch it hesatates for a half second to a second then takes off. I am thinking maybe fuel injectors of a tps any ideas let me know.
Old Mar 22, 2008 | 08:02 PM
87IROCZCamro's Avatar
Car: Chevrolet Camaro IROC-Z,96 Vette
Engine: 350 5.7 Liter
Transmission: 700r
Re: 305 tpi hesitates then takes off?
my ATV does that when its cold. But i dunno just throwing it out there
Old Mar 22, 2008 | 08:25 PM
Car: 90 IROC Z
Engine: 350 60 over
Axle/Gears: 3.08
i have been doing some digging and i think it might be the injectors i was just wondering if anyone had some thoughts and if anyone knew what the ohms was sopposed to be thanks
Old Mar 22, 2008 | 08:48 PM
Spitzfiya's Avatar
My Carburated 305 in my Firebird S/E does the same thing, try changing the fuel filter and doing a fuel system clean....should clear things right up
Sounds like fuel starvation.
I havent done this to my Firebird yet cause i don't know how to change the fuel filter (not on the fuel like most cars)
Old Mar 22, 2008 | 11:50 PM
Car: 90 IROC Z
Engine: 350 60 over
Axle/Gears: 3.08
yea I thought about that I was going to do a tank and pump change too.
Old Mar 23, 2008 | 12:08 AM
ljnowell's Avatar
underneath the car man.
Old Mar 24, 2008 | 06:55 AM
Car: 90 IROC Z
Engine: 350 60 over
Axle/Gears: 3.08
I am going to ohm out the injectors today and see what I get.
Old Mar 24, 2008 | 09:51 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
he said his is carbed if thats the case their is a little filter inside the front of the carb.
Old Mar 24, 2008 | 09:58 PM
WhiteIrocZ's Avatar
Car: 87 Iroc Z
I have the same problem too sometimes when my car is hot. I am pretty sure I have a leaking injector if not a few because it doesn't fire right up when it is hot, it has to turn over a few extra times. I have 22 lb. injectors ready to go in but no extra $$$ for the tuning require to change the injectors.
Old Mar 25, 2008 | 01:04 PM
91blue_phoenix's Avatar
Car: 2000 Ford Focus
Engine: 2.0L CVH/SPI I-4
Transmission: IB5
Axle/Gears: stock
I had the same problem with my 91 V6 for a long time. I did a tune up, fuel filter, and just for fun, threw a MAP sensor on it to. One of the three things listed fixed it. I doubt it was the tune up. The fuel filter could have been somewhat plugged, so that could've been the cause. The other thing is the MAP Sensor. If the MAP isin't reading properly, it'll run the car rich, or lean, but usually rich, causing black smoke at low RPMs, and when you hammer on it initialy. Just some suggestions.
Old Mar 26, 2008 | 06:55 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
My 93 pickup with a 4.3 V6 did that, off-idle hesitation. Changed the sparkplugs and that fixed it. The ones I took out looked just fine. (go figure)
Don't overlook the simple stuff .
Fuel starvation will affect the WOT horsepower output first. (ie: going up a long hill with the gas pedal on the floor)
gta90
Sep 15, 2015 04:00 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
