305TPI still running rich
Old Mar 24, 2008 | 12:47 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Today I installed a new O2 and CTS, and my car is still running slightly rich. The exhaust has a strong gas smell, and my BLM's are 123-125 at idle. Before changing the O2 sensor, the ECM was getting a false lean, and BLM's were at 158. Now, I get no SES light, and no error codes. Using WinALDL, I can see that the ECM seems to be fighting to try and adjust the fuel mix - one second the O2 will read lean, the next it will read rich, with the ECM constantly trying to compensate. The only thing left that I can think of would be bad injectors. They all tested right around 16.7 ohms, and I've confirmed that they hold pressure, after the pump is off. I put a long screwdriver on each one and listened to them with the engine running, and it almost seems like some are louder than others, but it could just be my imagination. Any ideas?
Old Mar 24, 2008 | 07:12 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
Re: 305TPI still running rich
what is your fuel preasure
how did you check the injectors for leakage
did you take the upper pleneum and runners off then lifted up the fuel rail with a towel underneath and turn the key and let the fuel pump prime
if not take it apart and check
Old Mar 24, 2008 | 03:43 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Fuel pressure is about 43psi, with the key forward and the engine off. It holds pressure after the fuel pump is off, so I don't think the injectors are leaking anywhere.
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
jbd1969
Aug 17, 2015 07:06 PM
tmellott89
Aug 16, 2015 02:58 PM
squiggy2
Aug 9, 2015 09:30 PM
