engine rebuilding help
Old Mar 24, 2008 | 09:50 PM
littlesk8cracke's Avatar
ok ill start by telling you what i have. its an 84 z28 but i have a 350 out of a 91 suburban in there. the engine could really use a rebuild so iv been looking into rebuild kits. i plan on doing the rebuild this summer. so can anyone help me out, tell me what to look for in a rebuild kit. maybe what to do while i have the engine out for a little more performance? thanks
Old Mar 24, 2008 | 11:00 PM
lukn4trbl's Avatar
Car: 2000 SS, M6
Engine: Modified LS1
Re: engine rebuilding help
What's your plan for the rebuild? Short block and top end ?How much more 'performance' would you like from this motor? That willset the stage for what suggestions are made.At a minimum, I would find a gasket kit, and replace the ignition components,and filters. If you have the motor out, replace the timing chain as well.That's a good start.
Old Mar 25, 2008 | 06:42 AM
well iv been looking at kits that contain things such as gaskets, timing chain, pistons, cams, stuff like that. on the rebuild alone i just wanna add maybe another 20-30 hp? im also gonna add headers and stuff like that. id like to make 250-300hp by the end of the rebuild. it has an edelbrock intake on it, and flowmasters, but other then that its basically stock. so what would i need to make a solid 300hp? im kind of new to this but im quite eager to learn about it so help me out. thanks!
Old Mar 25, 2008 | 07:09 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
take the motor out and send it to the machine shop
after the block, rods, crank and heads check out ask us again what to do when you post your findings
if you are buying stuff now or making any plans to buy stuff you are looking for a black string in a completly dark room
Infested
May 22, 2018 11:56 PM
backtothe80s
Sep 5, 2015 12:39 AM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
hokis
Aug 9, 2015 03:57 PM
