Gas Octane
Old Mar 30, 2008 | 04:32 PM
GoodlookinRS's Avatar
Car: 1986 corvette Z51
Transmission: doug nash 4+3 speed
Axle/Gears: 3:42 posi
Gas Octane
Ok i have a 305 tbi the octane i put in it is just regular like 89 or what ever so what would happen if i put like 104 octane? What would that do for like a 1/4 mile time?
thanks
kevin
Old Mar 30, 2008 | 06:35 PM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
Re: Gas Octane
thanks
kevin
higher octane is only meant for high compression/boosted application to prevent detonation, higher octane does not gain you any power, it has a higher tolerance to combust, that is all. you will make the most power by running the lowest octane possible without detonating.
by rule of thumb i have always did this.
8.5:1 and below = 87 octane
9.0:1 and below = 89 octane
above 9.0 = 91 octane
however this is not a definite answer and many other factors need to be taken in. it is only a guide. run the lowest octane possible without detonating and you are good.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
KCG
Jun 24, 2020 04:33 AM
86maro_252
Oct 10, 2015 06:52 PM
kx3g
Sep 28, 2015 08:14 AM
reactor60
Sep 22, 2015 01:44 PM
