383 Cam, Lunati 60101LK
Old Mar 31, 2008 | 11:37 AM
fastregalwe2's Avatar
For a mild 383, 601 heads, RPM air gap, and a carb, would this cam be a decent choice??? Street car mostly ....
Specs:
Basic Operating RPM Range:1,000-5,500Intake Duration at 050 inch Lift:213Exhaust Duration at 050 inch Lift:219Duration at 050 inch Lift:213 int./219 exh.Advertised Intake Duration:256Advertised Exhaust Duration:262Advertised Duration:256 int./262 exh.Intake Valve Lift with Factory Rocker Arm Ratio:0.454 in.Exhaust Valve Lift with Factory Rocker Arm Ratio:0.468 in.Valve Lift with Factory Rocker Arm Ratio:0.454 int./0.468 exh. liftLobe Separation (degrees):112
Old Mar 31, 2008 | 11:49 AM
ljnowell's Avatar
Re: 383 Cam, Lunati 60101LK
Specs:
Thats very mild for a 383, IMO. However, 601 heads fully ported are good for a 350, a little too little for a 383. I would swap heads, and then look for a better cam.
Old Apr 2, 2008 | 09:43 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
To answer your question yes. For a DD, mild 383, that is in the ball park. I run comps 12-408-8 which is real close, to what you posted. Lots of tire smoke with 3.07 gears. Idle is smooth, tq is great. Not the drag racers best, but good gas, 20 mph. Matches the tpi great.
Old Apr 2, 2008 | 09:58 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Whoa! You check your compression on this setup? "sky-high" isn't great eh?
Jorlain
Oct 8, 2015 01:57 AM
abray1
Sep 10, 2015 04:53 PM
john204481
Sep 7, 2015 03:22 PM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
Strick1
Sep 4, 2015 07:11 AM
