need help asap
Old Mar 31, 2008 | 02:22 PM
rocco 87's Avatar
Car: 87' Iroc Z-28
Engine: 5.0
need help asap
I've been workin on this car for about two years. within the first two months the fuel pump went bad. we replaced it and yesterday got it runnin and took it around the block. the first ride was perfect except the unbolted seats. but when my brother hoped in it went down hill. every time he touched the gas it would bog down . the people at advanced auto told us to replace the harness inside the fuel tank. i know some of these guys have no idea what they are talking about so i wanted to see if you guys could give me another possible answer.
btw i have and 87 305 tpi
Old Mar 31, 2008 | 02:50 PM
afida15's Avatar
Re: need help asap
maybe change your fuel filter. that would be the first thing i would do.
Old Mar 31, 2008 | 05:34 PM
ladyjynx's Avatar
Car: 1991 Camaro RS
Engine: 3.1L v6
Transmission: Automatic
Re: need help asap
You can also try checking your air filter, timing, and for vacuum leaks.
Old Apr 1, 2008 | 01:56 PM
rocco 87's Avatar
Car: 87' Iroc Z-28
Engine: 5.0
Re: need help asap
i have new K&N air filters and most of the vacuum lines were replaced. right now its timed only by ear. but the timing wouldnt affect it after one go around. it would have affected it from the start. ill have to check the fuel filter.
Old Apr 1, 2008 | 08:31 PM
91chevywt's Avatar
Re: need help asap
did you by chance replace the pulsator when you changed the pump? or the strainer? you may have a fuel pressure issue, would be good to check fuel pressure just to be sure
Old Apr 1, 2008 | 10:07 PM
rocco 87's Avatar
Car: 87' Iroc Z-28
Engine: 5.0
Re: need help asap
yes we tested the system. we didnt like measure it or anythin but the check valve barely spit out any fuel. thats why i figured maybe the wire went bad.
lol seems like every step forward is two steps back with these cars. cant complain though they are amazing.
Old Apr 2, 2008 | 09:13 PM
91chevywt's Avatar
Re: need help asap
Yea i agree these cars are pretty good when they're running. The best part is they have such a big fan base, thirdgen.org is a pretty amazing site. But anyway, you should probably check with a gauge, as 25-30 psi of fuel pressure can make a car run poorly. you need 41-46 psi. So did you change the pulsator or replace it with a piece of hose? They can cause pressure problems. Theyre actually known for causing pressure problems, pretty much a worthless piece if you ask me.
Old Apr 2, 2008 | 10:07 PM
rocco 87's Avatar
Car: 87' Iroc Z-28
Engine: 5.0
Re: need help asap
what exactly is the pulsator. do you have a pic
Old Apr 4, 2008 | 01:28 PM
91chevywt's Avatar
Re: need help asap
http://partimages2.genpt.com/partimages/259081.jpg
thats it-the top of your fuel pump should stick right into the bottom of this. Many people replace them with a piece of fuel injection hose and two fuel injection hose clamps. These things can cause low pressure situations when the rubber o-rings inside get cracked and such
92GTA
Apr 9, 2016 07:39 AM
86White_T/A305
Mar 6, 2016 01:48 PM
Brother Al
Oct 14, 2015 06:39 AM
92projectcamaro
Sep 24, 2015 08:09 AM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
