How do you ID a 305HO out of the car?
Old Apr 5, 2008 | 01:42 PM
TBITrucker's Avatar
Car: 88 Camaro
Engine: 305TBI
Transmission: Stock
Axle/Gears: 3.42?
How can I tell if I have a 305 HO motor. I was told the engine was a GM replacement 305HO crate motor.
The heads are 601's and have little circle tags epoxy glued on to them that say "Genuine GM Warranty Void if Removed"
The block casting number is 14010201
I was told the engine came out of a 95 Monte SS. The car was he shop were I got the motor, the motor was still on the hoist.
When I checked the block on More tech it doesn't have any notes about being and HO motor.
How do I know for Sure?
Old Apr 6, 2008 | 12:21 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
The only difference between an LG4 and L69 longblock ('85-up) is the cam. '82-'84 LG4's had dished pistons.
I assume you meant '85 Monte.
3rd gens didn't come with 601's, I can't say about Montes, though.
Put in a "known" cam, like a more modern aftermarket grind, and the whole thing will be moot.
Unless this "GM replacement 305HO crate motor" has dished pistons - a distinct possibility.
Old Apr 6, 2008 | 09:15 AM
TBITrucker's Avatar
Car: 88 Camaro
Engine: 305TBI
Transmission: Stock
Axle/Gears: 3.42?
Re: How do you ID a 305HO out of the car?
Thanks five 7
It is supposed to be a factory replacement 305HO.
I wanted to a way to find out if it has the higher compression ratio pistons without taking the heads off.
Old Apr 6, 2008 | 09:47 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Grab a flashlight and peer into the spark plug holes. Rotate the motor if necessary to see the tops of the pistons. You can see enough of the piston to tell if they are dished or not.
RBob.
Old Apr 6, 2008 | 01:14 PM
NowTheBadNews's Avatar
Car: 2006 Ford Mustang
Engine: 4.0 V-6
Transmission: Automatic
Axle/Gears: not sure
If it was a HO it would have a knock sensor. The early LG-4 till about 86-87 didn't have one. The HO always had a higher output alternator and you can tell by the alternators belt width its a little wider then the rest.
Old Apr 8, 2008 | 05:54 PM
TBITrucker's Avatar
Car: 88 Camaro
Engine: 305TBI
Transmission: Stock
Axle/Gears: 3.42?
It has the knock sensor.
No accy's or pulleys so I cant tell by that
I am gonna see if I can see enough of the piston trough the spark plug hole too.
Old Apr 9, 2008 | 08:30 PM
five7kid's Avatar
The car would have the knock sensor, not the replacement engine. That doesn't tell you anything.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
