Retrofit
Old Apr 11, 2008 | 01:32 AM
joshh44's Avatar
Car: 1990 T-Top Camaro RS
Engine: engineless
Transmission: Trannyless
Axle/Gears: 10 bolt/3.08. soon to be axleless
Retrofit
I been reading up some Retrofit cams for non roller engines.
since i got a non roller block that i have in the garage.
i found afew topics about this anthey say you need to go a thicker Timing chain cover, also some say you need to get a retro roller camshaft. others say you can just use a roller cam but you got to get the retrofit rollers. and others say you need to get a machine shop to machine the cam bores to fit a roller cam. iv read so many mixed answers that
im confuzzled. may someone explain these 2 answers?
DO I NEED TO BORE OUT CAMSHAFT BORES TO FIT ROLLER CAM?
DO I HAVE TO GET A RETRO CAM OR CAN I JUST GET ANY ROLLER CAM?
or should i stay with Flat Tappet?
my engine im hoping to make over 500hp or so.
im not to sure how much a flat tappet can take.
Old Apr 11, 2008 | 01:03 PM
SteelTownMadDog's Avatar
Re: Retrofit
You DON'T need to machine the cam bores...all SBC cam bores are the same size. You DO NEED retro-roller lifters & cam. You also need a thrust button & wear plate, and a thicker timing chain cover, or one with a recessed area where the cam button would sit.
Old Apr 11, 2008 | 01:35 PM
joshh44's Avatar
Engine: engineless
Re: Retrofit
thanks so much.
now im not so cunfuzed.
but may i ask. what is a thrust button and wear plate??
and is a cam button same as a thrust button?
Old Apr 11, 2008 | 01:54 PM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
Re: Retrofit
A wear plate goes between the block and the timing chain. What happens on a roller cam is they move back and forth in the block. The thrust button basically keeps the cam from moving too far forward and also keeps from wearing a hole in the cover. The wear plate keeps the timing chain from rubbing against the block.
If this is not going to be a daily driver and you want to make 500 hp, you should look into a solid roller.
www.geocities.com/dzperf
Old Apr 11, 2008 | 05:49 PM
joshh44's Avatar
Engine: engineless
Re: Retrofit
its not going to be a daily driver.
ill look into solid roller.
thanks for the info.
now im less confuzed. now i can start searching for a cam and some lifters
anesthes
Sep 18, 2015 12:34 PM
apie2546
Sep 4, 2015 03:47 PM
Fox118
Sep 1, 2015 04:07 PM
TPI Guy
Oct 19, 2001 02:37 PM
Fao's87T/A
Mar 13, 2001 08:53 PM
