Higher output alternator?
Old Apr 11, 2008 | 05:40 PM
British Rich's Avatar
Car: 92 Camaro RS
Axle/Gears: Stock
is there a performance alternator I can get? Any rcommendations?
or even better a bolt on version from a chevy truck or something that will work?
I ask because I suspect my alternator can't handle powering my amp (power line for amp reads 13v with engine off but drops to 9 when running)
(92 Camaro RS - stock)
Old Apr 11, 2008 | 07:57 PM
Comp788's Avatar
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
Re: Higher output alternator?
It would help if we know what alternator you have now? What amp is it?
Old Apr 11, 2008 | 09:15 PM
Car: 92 Camaro RS
Axle/Gears: Stock
I am assuming it's stock, and I have no idea what rating that is.
Old Apr 11, 2008 | 11:46 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Look for my thread in the electronics forum. I forget what I titled it, but similar to your thread "higher output alt". Searched under thread originator "sonix".
I ended up getting a CS144 from a 1995 Lumina van. 140A output, and factory reliability. Bolts up easily, just needed to tweak a wire. For a serp belt application it's a bit more tricky, but my thread has info on that.
oh hold on though, your explanation of why you need it doesn't make any sense. I don't think you NEED a bigger alternator, you need to troubleshoot your existing electrical system.
apie2546
Oct 16, 2016 02:24 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
6998poncho
Sep 25, 2015 02:56 PM
