can't go faster than 30mph
Old Apr 12, 2008 | 12:04 PM
pachucos's Avatar
My 86 TA cannot go faster than 30mph. the car starts up just fine. i can rev the engine as high as I want with out issues. I can drive the car all day at 25 mph but once i get to 30 -35 mph the rpm shoot up to 3500rpm, the only way to stop it is turn off the car. which then sputters and spits like it is flooded.
then it runs fine.
I have replaced the carb, fuel filter, mass air flow,EGR, cat, dist cap, rotor, plugs, plug cable, still the same.
I was told by someone that the carb it bad and another mechanic told me that the dist is bad.
I don't know who to believe anymore.
it is a 305 l4 carbed engine. if that helps.
has anyone seen this?
any ideas would be greatly appreciated.
Tom
Old Apr 12, 2008 | 02:37 PM
TheBigJ's Avatar
Car: 85 Firebird
Engine: SBC 383/88BW
Transmission: Built 700R4
Axle/Gears: Moser 9in/3.55
Re: can't go faster than 30mph
sounds like a transmission issue to me, hows that look?
Old Apr 12, 2008 | 02:42 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
I say carb.
At first glance you would think the tranny is slipping but I bet the throttle is not closing all the way on the carb.
Old Apr 12, 2008 | 03:10 PM
TheBigJ's Avatar
Car: 85 Firebird
Ohh good point
Old Apr 12, 2008 | 03:52 PM
1fastrock's Avatar
Car: 89 Camaro IROC
Engine: 383 Stroker
Transmission: turbo 400
i would have to guess the trans too.
Old Apr 12, 2008 | 04:13 PM
jayk2k3's Avatar
Car: 85 camaro z28
Transmission: auto to manaul
fuel pump
Old Apr 14, 2008 | 12:59 AM
Chris Knight's Avatar
Car: 1986 Iroc-Z
Engine: Orig. TPI + 305ci small block.
Transmission: Orig. factory 700R4
Axle/Gears: 3.23 G80
When the transmission went out in my car, I could put it in drive but once it hit 25 the rpms would sky rocket. I figured out when I put it into 2nd only, not drive, that I could drive the car up to 30-35 without revving it out. Mine is a 700R4 in a 86 Iroc, but I'm guessing the principle is the same. If it goes like mine did in 2nd, I'd say transmission. Other than that, I have no suggestions. Goodluck!
Old Apr 14, 2008 | 01:22 AM
Spitzfiya's Avatar
The governor went into school zone mode. I dont know beats me
God luck!
Old Apr 14, 2008 | 02:20 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
He suggests his engine wont climb over 3500, not slipping. if it slipped like a bad transmission, I would imagine he would say it revs like in neutral or something along those lines.
Old May 2, 2008 | 05:31 PM
pachucos's Avatar
ok so i verified no vacumn leaks,
it doesnt matter what gear i am in . i could be in 2,3, or 4th gear it still does the same.
new carb as of last year.
i did see if i rev up the car only while driving to 4000 + rpm that it does it also.
when idle i can rev it up as much as i want.
when it does do this, and i kill the engine it sputters and farts like it is way too rich.
I have verified that the choke is getting 11 volts to it.
I made sure that the choke coil is correctly placed in.
new fuel pump as of last year.
still no go
i am at loss. i dont what else to do.
no green
Mar 3, 2016 05:19 PM
toones
Jan 6, 2016 06:00 PM
Thirdgen89GTA
Oct 19, 2015 09:27 AM
Americanmouse
Sep 7, 2015 12:10 PM
luvofjah
Aftermarket Vendor Review
Aug 31, 2015 11:22 AM
