Ticking noise from heads
Old Apr 14, 2008 | 05:07 PM
EK76's Avatar
I've got this early 80s 305. There is a ticking sound coming from the right front cylinder head when the engine is cold and warming up (usually around 1100 rpm). Does anybody have any ideas of what this could be and how I could fix it.
Old Apr 14, 2008 | 09:47 PM
96_T/A's Avatar
Car: black '96 trans am
Engine: 5.7 350 LT1
Transmission: 4L60-E 3500 stall
Re: Ticking noise from heads
you could take off the valve cover and try tightening the valves. maybe one is loose or something
Old Apr 14, 2008 | 10:41 PM
91chevywt's Avatar
Not sure what youve got as far as a camshaft, but i'm guessing its got hydraulic lifters. So, usually a tapping hydraulic lifter when it's cold means its leaking down. They don't normally come out of adjustment, since theyre self adjusting. The only real way to fix this is to replace the lifter. Sometimes this noise happens when your low on oil, so you should be sure you have enough oil. Most of the time however, to quiet the noise people will use thicker motor oil, atf in their oil, or an oil additive like lucas oil stabilizer. So its up to you, you can "fix" it or repair it.
theshackle
Sep 17, 2020 08:26 AM
xxx3man`
Sep 23, 2015 10:37 PM
db057
Sep 4, 2015 07:57 AM
B_Dubya
Aug 26, 2015 05:09 PM
redmaroz
Aug 16, 2015 11:40 PM
