running to rich, how do i lean it out?
Old Apr 15, 2008 | 03:28 PM
jlc84cam350's Avatar
Car: 84 camaro, 92 yota 4runner
Engine: 305 lg4 out of 81 z28
Transmission: th350
Axle/Gears: Not sure believe its 3.23
ok, i fired up my lg4 305 for the first time in a while, having done some work to it and installed a new intake manifoil, its running way to rich, shooting gas out the carb! What screws do i need to play with and which dirction should i be turning to lean out, idle is good, rest is crap. Stock rochester carb.
Old Apr 15, 2008 | 04:15 PM
kjgroen's Avatar
Car: Trans Am
Engine: L69
Re: running to rich, how do i lean it out?
if it is overflowing most likely the accelerator pump is bad or the float is sticking!
Old Apr 15, 2008 | 08:46 PM
Transmission: th350
its ok one of my neigbours came to help me, apperently the choke wasn't set right, and the 2 plate that open, were always staying closed, even when floored. Also one of the vacuum lines for my coil wasn't correctly plugged, i didn't use the correct vacuum pluggin on the carb, thank god he was their, carburaturs are still surprizingle complicated when you have never worked with the hehe. now it seems to be puring like a kitten, needs oil change though, think i have got more gas in my oil than i do oil!!!
Azrael91966669
25
Jun 20, 2017 04:04 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
tmellott89
Aug 16, 2015 02:58 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
squiggy2
Aug 9, 2015 09:30 PM
